Old 22nd March 2012, 07:02 PM
thebluewhale's Avatar
Neil from what you've posted I'm pretty sure it's the Hall sensor.
This might be a coincidence but I've just had a leak on the steering rack fixed and now it smells like ATF is dropping onto the near side cat but I had the output seal done on the gearbox a couple of years ago.
I don't know if the smell and the crank sensor going faulty are related as both started within days of each other.
Is there anything else down there that can leak ATF?
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 22nd March 2012, 07:27 PM
The one Neil posted is camshaft position sensor. It could be causing the problem as well. I would not be throwing money around before diagnosing the exact fault. Anyway crank sensor would be this one:
Old 23rd March 2012, 03:58 PM
I've taken your advice and booked it in with Unit 20. The probability is the crank sensor but just to be sure.
Thanks for placing that seed of doubt ainarssems
Old 3rd April 2012, 07:26 PM
Give yourselves a pat on the back. You were right.
I've had the crank sensor replaced by the lovely peeps at Unit 20. She now starts everytime.
Happy days
Old 3rd April 2012, 07:51 PM
Red face
Nice one!
Old 3rd April 2012, 08:55 PM
grizz grizz is offline
Only too glad to help ..
Old 29th May 2012, 09:06 PM
richyb66 richyb66 is offline
Looks like I'm starting to get these symptoms too - difficulty starting, especially when hot. However it still struggles when starting from cold in the mornings (did it today). Once it's been running a few minutes it's fine, by which time it's switched over to lpg.
The temp gauge works fine but I'm wondering if the ecu uses a seperate temp sensor to the gauge and maybe it's playing up as so can't adjust the fueling correctly when it's starting? I can test the crank sensor as described on Elsawin and at least it doesn't sound to bad to swap.
