Old 25th April 2009, 09:06 AM
Avus
Guest
Posts: n/a
Default The Glovebox
My glovebox will not open via the button. I have found the temporary workaround by pulling the cable under the dash, but I am wondering if there is a more permanent solution?
Old 25th April 2009, 02:31 PM
Sounds like the operating mech is duff. Try A8Parts with the part number 4D0 601 170 A. Keep you existing lock barrel and swap them about when you get the operating mech.
Old 26th April 2009, 01:11 PM
Avus
Guest
Posts: n/a
Great info, cheers for that.
Old 28th April 2009, 07:37 AM
If the mech works, but wont drop, it might just be that the mech needs adjusting - There are two allen bolts, 4mm I think, and they can be used to adjust where the mech 'grabs' the bar.
Failing that, we have plenty of gloveboxes, but the mechanisms did change over the years, so we'll need your registration no to work out which one you have
