Old 28th March 2012, 07:16 AM
Nollywood's Avatar
Price isn't the issue, I'd glady upgrade but the airbags aren't compatible. The four spoke wheel (I'm selling) feels horribly thin and TDI like, some like it, I can't stand it.
I agree - in my opinion, the ergonomics and looks of the standard three-spoke Sports wheel heavily outweigh the "convenience" of controlling the audio from the wheel with the four-spoke MFSW. To some though, it could be a God-send.
The flat-bottomed B7 RS4 steering has twin-stage airbag, and so is not directly compatible. But it can be fitted, and wired correctly to a single-stage chassis.
Old 28th March 2012, 08:23 AM
Nollywood, yep I guess so, sounds like it won't be as much use to me anymore and yes I'm getting the three spoke as I don't like the four spoke. I'll need to ask the guy selling me the three spoke for the slip ring thing, thanks for the heads up on that.
You need to do some rewiring for this Amar. Going from a MFSW to a Tiptronic (paddle) wheel is almost as much work as going the other way.
The current MFSW slip ring has the horn and airbag connections, which can be reused, but everything else is sent over a databus from the MFSW controller. You will need to find the tiptronic up and down wires, and run them up to the back of the new slip ring on the steering column. I cant remember if the paddle shifts are illuminated like the tip up/down on the MFSW - If so, you need to bring a feed for the illumination from the tiptronic selector too.
Not hugely difficult, but not a 2 minute swop either.
It will be hugely beneficial to the new buyer if you sell the slip ring and any snipped off connectors with the steering wheel as it will be a far more useful complete retrofit kit....
Old 28th March 2012, 08:28 AM
Thanks Ian, I'm going to ask MRC Tuning to fit it, would rather not experiment with airbags and things myself.
Old 28th March 2012, 11:10 AM
Guys, could someone please tell me what part number the slip ring that I need will be? My new steering wheel won't come with this so I need to get it ordered asap. Thanks guys.
P.S Is the slip ring all I will need?
Old 28th March 2012, 11:24 AM
Speak to a8parts. The slipring for the RS6 paddle wheel should be the same as from any D2 sport with tiptronic change.
Olis D2 conversion from a tiptronic 3 spoke to RS6 paddle was a 5 minute straight changeover.
You'll probably need wiring connectors too as the pins will differ....
Old 28th March 2012, 11:26 AM
Actually, I correct myself.
It was a 5 minute change to put the Rs6 wheel on the D2 PF S8 I had it on.
It was a PITA to put it on Olis car as it had originally an early MFSW and needed all thw wiring doing...
Old 28th March 2012, 11:38 AM
Hmm, so will it be easy or hard to do on my MFSW equipped car, Ian? MRC have said 30 mins labour. I haven't been able to get an airbag with the three spoke wheel so I am buying this to use the airbag.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
Should work, shoudln't it?
Old 28th March 2012, 05:20 PM
Grizz has very kindly been in touch and told me that Ekta lists the same slip ring for both the multifunction steering wheel and the three spoke. My current four spoke steering wheel also has tiptronic shifters on it, I am guessing you guys thought I needed the slip ring as my four spoke didn't have tiptronic shifting on it? This seems to be the part number for the shift ring thing.
1J0959654M
