Old 5th April 2012, 06:17 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Default Updating MMI
Got an error can't find module BO_D3...anyone got any ideas?
A8OC Founder
The A8 Owners Club here
Old 5th April 2012, 06:33 PM
Everything working OK otherwise?
Do you have B&O?
Old 5th April 2012, 06:46 PM
A8_Tony's Avatar
Think it's going through now
Just trying to work out how to remove the cubby hole :confused: doh!!
A8OC Founder
Old 5th April 2012, 07:20 PM
cubby hole has clips at the sides, not the top or bottom (i assume you mean the glovebox one).
You sometimes need to run the CDs 2 or 3 times to make sure it got everything.
Old 5th April 2012, 07:22 PM
A8_Tony's Avatar
Ah ha!....I guess the clips are located at the front?
Almost there with the update....telephone is showing as not installed, but I'm just running disk 3 through now...hopefully that'll sort the last bits out
A8OC Founder
Old 5th April 2012, 07:54 PM
A8_Tony's Avatar
Going relatively smoothly....although telephone & DVB don't seem to be working at the mo.
Can a mod move this thread to the proper section when they get a mo? I posted in the wrong bloody place :confused:
A8OC Founder
Old 5th April 2012, 08:03 PM
disk 2 needs run a couple of times to do the phone.. takes fookin aaaaaaaaages!!
DVB may have hit CP, but not sure, run all the disks again
Old 5th April 2012, 08:05 PM
A8_Tony's Avatar
tried running disk 1 again, but it says there's nothing to update. Disk 2 is running through again now
Bloody pain in the bum if the TV has hit CP, but then again, I don't really use it, so it can wait until I can be arsed to go into a dealer
Next job? fit the AMI unit
A8OC Founder
Old 5th April 2012, 08:07 PM
dont worry the ami will only take 5 minutes
Old 5th April 2012, 08:34 PM
I assume you're doing the AMI as a parallel install rather than a swap? that's a bit more fiddle as you need to drop the globox out to run all the cables usually. Unless you really need to use the CD changer again, just swap it.
