Go Back   A8 Parts Forum > Our Other Audi Friends > A6/S6/RS6 C5
A6/S6/RS6 C5 1997-2004
Old 5th April 2012, 08:04 PM
and made...
Us all a little jealous... But then again, I was doing 40mpg for a laugh earlier today
Old 5th April 2012, 08:32 PM
thebluewhale's Avatar
Nice torque figure and not a bad power gain on standard turbos.
Would you have to upgrade to hybrids for more power?
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 5th April 2012, 09:11 PM
Standard turbos will do 550 BHP, you need to change the manifolds to get past that. Amanda's Loba turbos are rated to 650 BHP, but on standard manifolds it's hard/impossible to get past 550 BHP. I would rather spend the money going for the V10 version which go to 700 BHP, 900NM with just a remap then replace internal engine bits. Amanda however loves the C5 so is going for the full 650 BHP. The highest I've seen dyno on standard turbos/manifolds is 558 BHP with the same spec as mine but it also had Wagner intercoolers which are twice as big.
Old 5th April 2012, 09:25 PM
Tesco super unleaded doesn't get the best write up either - generally not well regarded against a proper high octane fuel. Mind you since shell have chosen not to ship v-power at the moment it's a bit tricky to find super anywhere! Filled mine up with 95 as fed up looking for dregs at stations wherever I go!
Power results sound pretty good to me - I'm sure that'll be felt on test drive, along with single figures economy if you use it all lol
Old 5th April 2012, 09:34 PM
Yeah, I hope I can feel the change, my wallet certainly will.
Adrian, Tesco Moumentum 99 is regarded by most on SRS as the best fuel and rated much higher then V Power. Throney Motorsport done a test with that vs V Power and T99 came out much better. Also, MRC have had cars on 95 RON on their dyno then they put in T99 and they get about 20 BHP more.
I have been rocking BP 97, but manages to squeese in £97ish of T99 today, tanker was just leaving with 'Moumentum' written on the side of it as I entered the petrol station.
Old 5th April 2012, 09:59 PM
That's interesting - my recollection of a technical article I read was that the method by which the octane is boosted is more volatile in the Tesco fuel so will go off faster and not be as consistent as fuel brewed with a higher octane in the 1st place. The suggestion being that the Tesco fuel was a 95 octane boosted up with additives rather than a genuine 97-99 octane at the processing stage. I suspect the regularity the tanks get refilled plays a big part, so a slow selling super unleaded will probably have a lower octane than you think you're getting.
Probably all marketing bollocks either way, to be honest, but I generally don't trust supermarket fuels at all unless the car in question pre-dates unleaded!
I suspect 20bhp measured on a dyno won't feel much different when you're pulling figures like these
Old 5th April 2012, 10:06 PM
Think this is the link.
http://www.thorneymotorsport.co.uk/t...s_Update.shtml
Tesco 99 did come out number one, followed by V Power and BP Ultimate is only 97 RON, so I avoid that as owners manual specifies 98 RON as recommended fuel, anything less is ok for emergencies but I should keep revs to a minuim.
Old 20th June 2012, 08:13 PM
frankow's Avatar
frankow frankow is offline
Hi Amar,
Nice figures and a lovely looking car. You have had it a while now, must be time for a change
Just a quick word about Momentum, it contains quite a high proportion of biofuel (ethanol) which is great for making power but can cause chaos with internal engine components, notably rubber seals.
Someone correct me if I am talking but I did a lot of research on fuel a year or so back.
A topic which creates a great deal of debate!.
Old 20th June 2012, 09:47 PM
Hi Wayne, brief post as out in the Florida Keys at the moment. But all fuel has ethanol in it now, even V Power!
