Old 5th April 2012, 08:47 PM
I assume you're doing the AMI as a parallel install rather than a swap? that's a bit more fiddle as you need to drop the globox out to run all the cables usually. Unless you really need to use the CD changer again, just swap it.
Nah, with a bit skill (and some slightly sore knuckles I confess) its quite possible to to the parallel install without dropping the grovebox. Pop the cubby and CD changer out to give access and away you go...
