Old 5th April 2012, 08:47 PM
I assume you're doing the AMI as a parallel install rather than a swap? that's a bit more fiddle as you need to drop the globox out to run all the cables usually. Unless you really need to use the CD changer again, just swap it.
Nah, with a bit skill (and some slightly sore knuckles I confess) its quite possible to to the parallel install without dropping the grovebox. Pop the cubby and CD changer out to give access and away you go...
Old 5th April 2012, 09:19 PM
OK.. less easy for those of us with ape hands... Though if you have a spare 10 year old it could work
Old 5th April 2012, 09:21 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
All done
DVB-T isn't playing, so I'm going to run the disks again over the weekend.
Parallel installed the AMI, and to be honest, wished I'd dropped the glove box...cable-routing is a pain in the arse when they just don't want to go where you want them
Telephone isn't reading my phonebook. But I'm going to guess that's because I've got an Android phone, and all of my contacts are actually stored in the cloud, rather than on the phone/sim...anyone got any experience/tips on this? As I actually rather like having control of my contacts via Google. It's an HTC Sensation, which I'm sure I paired up with my old '57 A6
Only niggle? The bloody USB-Mini USB cable is waaaaayy too long :P
A8OC Founder
The A8 Owners Club here
Old 6th April 2012, 12:05 AM
Thread moved
On my A7 the contacts didnt transfer either like this so in the end I copied the contacts onto an SD card then imported them onto the MMI - if you can try that it might work Tony ?
Old 6th April 2012, 09:25 AM
A8_Tony's Avatar
Thread moved
Not an option for me chap, no SD card reader in the '8
A8OC Founder
Old 6th April 2012, 09:57 AM
Which version of Android do you have on the phone Tony?
Has the update sorted it? Though I'm also discovering the joys of the crap iPhone 4 connectivity to the later bluetooth kits.
Old 6th April 2012, 09:59 AM
A8_Tony's Avatar
Got the phone connected now, but no phonebook import option
Going to try a couple of things:
1. Remove pairing from car & phone.
2. Reset Telephone module.
3. Re-pair phone to car.
Will let you know how I get on, as gotta take girls out now
A8OC Founder
Old 6th April 2012, 06:26 PM
A8_Tony's Avatar
Well that didn't bloody work!!
Frustrating as hell, might have to try my Desire HD and see if I get the same issue. If I do it's likely to be OS/Contact storage related. If not it's down to the phone gggrrrrrr
A8OC Founder
Old 6th April 2012, 06:48 PM
What you need is an rSAP adaptor!!
Ahemmm I happen to know someone who has one
Old 8th April 2012, 09:06 PM
A8_Tony's Avatar
Unfortunately Neil, the rSAP adaptor would not be useful for me. Android phones apparently don't have an rSAP protocol built into them.
However, I've fixed the issue now, deleted my call logs, and job's a good 'un
A8OC Founder
