Old 8th April 2012, 07:39 AM
finally it works
there was no problem with the sensor in the first place, after getting the bumper cover pulled forward , was able to see that the connector wasnt connected to the sensor, plugging it in worked wonders
took aout 3 hours in all , but saved 600 squid
Old 9th April 2012, 05:46 PM
thebluewhale's Avatar
Is the PDC sensor the same for the D2 and the D3? I don't have access to Etka/Elsawin whatever it is.
I need two for mine and if they come painted even better.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Last edited by thebluewhale; 9th April 2012 at 05:47 PM. Reason: Can't write sentences that make sense :-)
Old 10th April 2012, 03:39 PM
Don't think they're the same - do you know which you need? Think inner and outer are different but can easily check for you and post part numbers
They don't come painted so as an example, getting them done properly by a body shop they came in at 90 quid painted each for my a6
A lot of places will rattle can them and lacquer (if you're lucky!) and the finish won't survive a pressure wash which will look cack on your car
Old 10th April 2012, 03:44 PM
It's the two front inner sensors that have gone.
Why would the inner and outer be different?
Old 10th April 2012, 04:51 PM
No idea, but I know they are different on the front of my A6 - will check part numbers when I'm in front of my laptop and let you know. I assume they have a different range/angle setup or something....
Old 10th April 2012, 04:58 PM
Cheers Adrian
Old 10th April 2012, 05:53 PM
They are the same all around front and back
The support for them are different front and rear of the car
The brackets for the sensors at the front are same left and left centre and then different for right and right centre
4B0 919 275 A GRU Ultrasound sensor - primed
Primed they are about £67.29 each + vat but they are available in colours I believe
Old 10th April 2012, 06:00 PM
Thanks Neil,
Why are the D2 parking sensors more expensive than the D3 ones? Any difference apart from the part number?
The German site 47p2 posted they are about £20 each.
Old 10th April 2012, 06:34 PM
looks like the same guy does the d2 ones as i got mine from
http://www.ebay.co.uk/itm/NEU-AUDI-P...item1e697b62a3
arrived quickly redy painted and had a small bag of haribo in the box , what more can you want
Old 10th April 2012, 09:03 PM
Amanda Amanda is offline
My parking sensor sexy very much so
