Old 24th January 2011, 08:09 AM
Yep, it was the sensor and the connector. Apparently, water runs down the cable, corrodes the connector and then b*****s up the sensor. I was quoted £170 but, because someone used the connector that was ordered for me the day before I was booked in, and I sat in the cold waiting room for three and a half hours waiting for another connector to be delivered, the nice folk at A4 Audi (Clydebank, Glasgow) charged parts only (£106), threw in the touch-up paint I'd ordered for the parking sensor and gave me a case of lager!
Now that's good customer relations, don't you think?
Old 1st December 2011, 11:30 PM
A8 parts sent me a front sensor for (I think) 30 quid.
It's an easy DIY job to fit it.
Old 14th April 2012, 09:07 PM
Same car (IceBlue8's) and same fault. presumably the other sensor has gone. I have looked at both front and rear sensors but cant tell which is the newer and Jim can't recall which was replaced. Is it possible/necessary to get it checked with VAG com to establish which one is u/s or would it be advisable just to order the part and fault-find by replacement? (Are they the same part?).
Old 14th April 2012, 09:10 PM
Not sure id VCDS tells you, but I'm sure A4 would know which one.
Old 14th April 2012, 09:12 PM
Good point - i am sure they would have a record. (its not on the invoice/work record which Jim handed over with the car).
Old 15th April 2012, 11:01 AM
ADU UR quattro ADU UR quattro is offline
Thanks for posting this up,Now I know what needs to be done.The top section of my DIS ( the part that shows the radio information has had a yellow hoeadlight symbol with up/down arrow.vagcom reprting G76 andG78 sensors faulty,I got MOT coming up next month, so will get it sorted then.
Thanks for the information.
Old 15th April 2012, 05:29 PM
From what you say vagcom doesnt differentiate between the front and back sensors then?
or maybe you have both faulty?!
Old 15th April 2012, 06:38 PM
01539-Headlights Not Adjusted
35-00 --
00774- Level Control System Sensor;Left Rear (G76)
28-00 -Short to Plus
00776-Level Control System Sensor ;Left Front (G78)
28-10- Short to Plus- intermittent
I hope this helps.
Old 15th April 2012, 07:02 PM
35-00 --
I hope this helps.
Yes it does. Many thanks.
Old 16th April 2012, 07:45 AM
I had a word with A4 Audi and they don't know which one was done, but Andy says you should be able to tell as the repaired one will have new yellow wiring.
But apparently they're having trouble with repaired/replaced sensors failing again as the water still runs down the wiring into the sensor. Current methodology is to use a inner tube to cover the wiring from top to bottom!
