Apologies for the copy/paste from the suspension forum but that one seems to have gone a bit quiet recently.....
Ok - I finally bit the bullet and replaced the other front air shock today. Thankfully, the compressor hasn't got to the point of self destruction yet, so it works however.....I no longer have the option to select the ride through the car menu in the MMI and the settings menu now says "no further settings for this vehicle" or similar - no option for jacking mode / towing mode. The system works and raises the car, VAG_COM shows no faults but can't change anything. I also tried going into the hidden menu to see if anything was disabled - it doesn't seem to BUT I also can't get into the "vehicle" sub-menu - nothing happens. This may or may not be linked to a battery failure last week - I left the suspension in jacking mode overnight to avoid overstressing the compressor but it appears to have drained the battery - next day it was totally dead. I recharged it and cleared the myriad of faults thrown up by it but this seems to be the only remaining symptom. Anyone have any clues? |
Have you tried disconnecting the battery to see if it does a reset?
. Nite Blue 3.0L SE Quattro |
Haven't tried it - wouldn't that just give a whole load of error messages?
Off to try resetting the MMI and see what that does. Update - nothing whatsoever. Getting late now, will fiddle with it some more tomorrow. Last edited by Stuarta; 17th April 2012 at 04:49 PM. |
Disconnecting the battery should not give any errors.
The proper procedure is:- Switch the vehicle off and wait 20 minutes, then disconnect the negative lead, then disconnect the positive lead, then using a jump lead (piece of wire that has two crocodile clips) join the positive and negative leads together and leave them for 15 minutes. After 15 minutes remove the jump lead (crocodile clips) and reconnect the positive lead to the battery terminal and tighten up, then reconnect the negative lead to the battery and tighten up. Start up the engine. Jump lead with crocodile clips..... Must not be connected to any terminals that are still connected to a battery ![]()
Thanks - will give it a go tomorrow and report back.
Well I finally managed to get the system working - the suspension, that is, not the MMI controls.
I'm a bit worrid now of frying the modules I just got working again, so will wait a day or two before trying this. I already tried updating the MMI from 5150 to 5570, which I'd been planning on doing anyway but that had no effect. In the meantime, if anyone has more ideas of how to bring the controls back, I'm all ears. Thanks to all for the help. ![]() |
There are some bits in the hidden menu, dont know if they are the answer, but might tell you something, but obviously be careful in there
if you goto Car Menu Maske > Car View options > there is an option called Air Suspension also in Diag settings > HU Codierung there is another called Karosserie - body. This allows the correct thumbnail is displayed in settings such as vehicle suspension height. Equivalent to encoding module 07 in position x? Xxx. in Diag settings > APK 0 × 01, 0x0B, 0x0C > Ports Driver 07th Air suspension - activation of the adaptive suspension. Equivalent adaptation module 07, channel 1, the value of the 64th
A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
Car menu maske is the same place where you turn on and of the mmi batery and oil meters, so is a good possibility
Thanks - I did try that on the old version - will go and try disabling / enabling - see what happens.....
![]() 2005 A8L W12 Almond Beige 2008 Jaguar XK Convertible 1971 Jensen Interceptor II (soon to be Mendip Blue) |
Limocello - you are a genius!
the problem lay in Quote:
![]() ![]() I always did love limoncello!
