Old 21st April 2012, 06:34 PM
The plot thickens.
Removed some more stuff out of the way for access, bought a new compression tester, and tested all cylinders, and both banks.
I have 2 cylinders off, both opposite each other on seperate banks, both reading a value of around 4 bar, compared to the 9/10 bar on the healthy cylinders.
Defo an engine swap / breaker now, but what are the odds of having two cylinders broken..... ???
Old 23rd April 2012, 06:30 PM
adjuster adjuster is offline
I don't have much experience with the LPG fueled engines, but I've seen where an injector sticks open, and will flood the cyc. with fuel.
This washes the rings, and drops compression, and of course, the super rich mix does not burn, so you get a misfire.
Wet plug and low compression were what I found. Added some oil, it brought compression up, but as soon as the engine was run, it misfired again.
Pulled the injector, swapped it with another, and the "bad" cyc moved...
Sonic cleaned all the injectors, and it "cured" the problem for that vehicle. If not, I was ready to replace the bad/stuck injector. (But upon pulling them, they were all filthy, so new fuel filter, sonic cleaned the injectors, keeping the bad one seperate so it did not get confused with the other 5 on this I6 engine.)
The coil and plug was fine, the valves and pistons were fine. Rings were fine, but washed with too much fuel, they don't seal up well at all.
I would imagine if you ran the engine at a high enough speed/RPM, that the right air fuel ratio would be reached, and the misfire would go away. (Depends on how stuck open the injector is.)
Old 23rd April 2012, 07:40 PM
Hmmm - Thanks for that. Thats very interesting.
I do now have 2 cylinders off, and I just cannot get my head around the miniscule probability that I have two failed cylinders.
More interesting is that whilst they both read only 4 bar of pressure, only one of them has a wet plug. The other is dry.
I wonder thus if I might have one failed valve/piston, and one injector problem....
Time for some more spanner work me thinks...
Old 24th April 2012, 11:25 AM
Zip's Avatar
Zip Zip is offline
Question
Sorry for off-topic question......
what's a "Hertz" audio upgrade when it's at home?
Zip
Old 24th April 2012, 02:28 PM
If it's the one I'm thinking of, then it's aftermarket stereo gear... along the lines of Bose, etc.
Old 26th April 2012, 02:24 PM
SyncroS8 SyncroS8 is offline
The plot thickens.
I have seen the oil squirter break off and score the bore on a 32V. Not common though.
I'd see if you can borrow an endoscope if you can and have a look down the spark plug hole.
You can replace pistons without having to drop the whole engine but by the time you've pulled the sub-frame off to get to the sump, setup an alternative support for the engine, pulled the heads off (exhaust etc), it might be just as easy to pull the engine.
I'm very glad that I carried out a compression test on my S8 before parting with my cash
I feel for your mate although you did buy it knowing that it had engine problems.
I'm still interested in the LPG setup
MG
Old 19th May 2012, 09:56 PM
Good to see the car today and confirm that the compression on cylinders 2 and 7 were very low... A little bit of oil in the bores confirmed rings and cylinder issues rather than valves.
Never heard such a sick sounding V8.
MG
Old 19th May 2012, 10:00 PM
I thought it was 2 and 6...... ?
Yes, very sick, but thanks for your input, and still quicker than most things
Old 19th May 2012, 10:45 PM
Maybe I'm getting the numbering of the cylinders wrong...
Cylinder 1 and 8 are at the crank pulley end?
MG
Old 19th May 2012, 10:51 PM
1 and 5 i believe at crank pulley end.
I traced cylinder 6 from the wiring colour of the coil packs... cylinder 2 was my unknown, but we seem to agree on
