I believe there are 3 tuners..
Analogue - Standard on older D3 Digital - Optional Hybrid - Standard on 'newer' D3 I think if you get the Digital only one, you need the Analogue for the output functions, but I may be wrong ![]()
that sound about right so the Hybrid is a straight swap roger that
i just put all three in , worth it while youve got the plug off
http://www.ebay.co.uk/itm/CT29AU02-A...item255e3f5e70 this is the one, i got them from a non ebay shop though about £12 each, have i search though one place was doing 2 together cant remember how much will look up where i got mine, they are not all equal, some have thick wires which make it difficult to get the in the connector
A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
Cool Thanks for that, this is the rear camera i bought http://www.ebay.co.uk/itm/Rear-View-...#ht_2571wt_698
and i thought with the Av it should work but on the Av list inside the car there is Av 1 and Av 2 so if there is only three head on that cable with your link dose that mean that i would only have 1 Av or would i need to buy 2 Cables ? |
what i thought i could do is take the voltage for the camera from the reverse lights then code it so when it goes into reverse the Tv switches to Av 1 and then the power comes from the reverse lights, or have it so that its live all the time so i can just switch to Av anytime and then see whats behind me even if im driving on a motor way ? do you think i would need anything else other than the camera the av cable and just wire it up ?
Each cable (as per the link) gives you one AV input, on mine i have put 3 cables in, so i have AV1, AV2 and AV out which goes to (or will ) the rear headrests,
its not that diffcult to do, justr drop the nav drive down, and open the 20 pin red socket, but its fiddly so its a chance to put 2 or 3 in at the same time.
heres the pins
aux1 --------------------- video - 13 video + 12 audio(L) 10 audio(R) 11 audi0 - 9 aux2 ---------------------- Video + 18 video - 19 audio (L) 16 Audio (R) 17 Audio - 15 OUTPUT ----------------------------- Video + 5 Video - 4 Audio (L) 7 AUDIO (R) 8 Audio - 6
