Old 29th April 2012, 10:04 AM
what i thought i could do is take the voltage for the camera from the reverse lights then code it so when it goes into reverse the Tv switches to Av 1 and then the power comes from the reverse lights, or have it so that its live all the time so i can just switch to Av anytime and then see whats behind me even if im driving on a motor way ? do you think i would need anything else other than the camera the av cable and just wire it up ?
Old 29th April 2012, 12:28 PM
Each cable (as per the link) gives you one AV input, on mine i have put 3 cables in, so i have AV1, AV2 and AV out which goes to (or will ) the rear headrests,
its not that diffcult to do, justr drop the nav drive down, and open the 20 pin red socket, but its fiddly so its a chance to put 2 or 3 in at the same time.
Old 29th April 2012, 12:30 PM
heres the pins
aux1
video - 13
video + 12
audio(L) 10
audio(R) 11
audi0 - 9
aux2
Video + 18
video - 19
audio (L) 16
Audio (R) 17
Audio - 15
OUTPUT
Video + 5
Video - 4
Audio (L) 7
AUDIO (R) 8
Audio - 6
Old 29th April 2012, 12:35 PM
Ah i see, so if i buy 2 or 3 cables i can then use them for quite a few things and pin them in to the block, ! thanks you very much for the help i will order them and see if i can get it all sorted ! by any chance do you have a link to the Non Ebay listing that was £12 each rather than 24 odd each as i will get 3 of them it will hurt the wallet less
Old 29th April 2012, 12:47 PM
im not sure what one i got it from now, this one is £14
http://www.caraudiodirect.co.uk/con-...udi-a6-a8.html
try googling CT29AU02 see if anyones cheaper, im sure there were some for 12ish
Old 29th April 2012, 04:58 PM
Kufatec do them too... abotu 12 quid each, but delivery is expensive, so best to get 3 at once
Old 4th May 2012, 04:01 PM
Somerandomguy's Avatar
Not sure you still need these - I bought my cables from Germany a little cheaper, and only tok a few days to arrive:
http://www.ebay.co.uk/itm/TV-Tuner-A...ht_3191wt_1163
good luck
