Old 9th May 2012, 05:11 PM
47p2's Avatar
47p2 47p2 is offline
Default Time for an oil change
So the A8 was out and about today and when I returned home I decided to do an oil change. Well whoever tightened the sump plug last time must have used the old washer and hiked the plug up as tight as he could. I had to use a 2' breaker bar to remove it
In the air and oil draining
Not a lot of room for a LWB up here...The guys at the Mini-Meet will remember the rope trick
and the rear
I'll let it drain for a while yet before stitching it all back together
Nite Blue 3.0L SE Quattro
Old 9th May 2012, 05:17 PM
Ah... the old "Glasweigan Rope Trick"... works a treat
Still ever so slightly jealous of the garage...
Old 9th May 2012, 06:22 PM
I want your life.
Old 9th May 2012, 08:49 PM
47p2's Avatar
I want your life.
pm me your address and I'll send SWMBO down then
The oil filter is sited under the engine cover
32mm socket required
Oil filter has a small extension which has a seal on it, this faces downwards and locates into a hole at the bottom of the filter housing
All finished
Tools required
Stubby flat blade screwdriver to remove the engine undertray
10mm Hex for sump plug
32mm socket for filter cover
Components required
9.2 litres oil to Audi spec
New crush washer for sump plug
New oil filter
Old 16th May 2012, 01:56 PM
47p2's Avatar
Heads up for anyone looking for cheap oil, TPS have a promotion on at the moment on 20 litres drums of 507.00 Quantum Long Life 3
