Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 21st January 2009, 12:45 PM
A8 Doc A8 Doc is offline
Default ESP Light - Random Always On
Symptom - ESP Light will appear on cannot be switched off without restarting the engine. Will appear under either light or hard braking.
Solution - Brake pedal switch. Remove lower driver side panel with Torx screwdriver. Remove air ducting and reach up. Undo electrical clip and twist the switch. Install switch and reverse the stripdown.
Old 15th May 2012, 01:45 PM
zed zed is offline
Would a fault code show up in VCDS fro this?
Thanks
Old 15th May 2012, 02:20 PM
Maybe... Are you getting those symptons?
One way to test may be to have someone at the back of the car, and see how much pressure on the pedal it takes to pop the brake lights on.
Old 15th May 2012, 04:57 PM
47p2's Avatar
47p2 47p2 is offline
....or back it up close to a wall when it's dark and press the brake light
Nite Blue 3.0L SE Quattro
Old 15th May 2012, 05:22 PM
Or use a mate you don't like, and keep it in reverse
Old 15th May 2012, 05:48 PM
sloss's Avatar
sloss sloss is offline
Old 17th May 2012, 10:18 PM
zed zed is offline
I don't think my issue is related to the brake switch now, the ESP light seems to be randomly coming on.
I just had it scanned, and is showing 'brake pressure sensor - electrical fault in circuit'
Old 11th September 2012, 10:48 AM
For what it costs to replace it I would just do it with a new item.
That fixed mine as it randomly came on.
Old 12th September 2012, 05:46 AM
Brake switch and brake pressure sensor that's not the same thing is it?
Old 12th September 2012, 06:13 AM
47p2's Avatar
No, two different items
