It's kind of conical, round (ball type if you wish) joint without gasket that allows slightly different angles and movement in joint sealing at the same time
Thanks for that, sounds like some manifolds I've seem before (SD1 Rover possibly?). A very light smear of paste won't hurt.
My new cats should arrive tomorrow, just need to sort out a pair of pre-cat lambda sensors and I'm all set for the weekend. |
Be careful with paste some can damage cats and lambdas
I'll be sparing with it. What I'll probably do is loose fit everything so that the outlet of the down pipe is connected to the rest of the system and then loosen the connection at the manifold and apply a smear of paste before tightening it up.
If I go for lots of paste and leave the downpipe dangling or waggling around, some paste will no doubt drop down onto the cats. |
i would not bother with paste to be honest, the joints that ainarssems mentioned are expantion joints when fitted together and tightened up when the system gets hot it expands and creates a perfect seal and if you put any compound on there it might make the joint not seat correctly and might not seal when hot
![]() just my 2 pence worth |
New cats arrived this morning. The sealing face is indeed conical so if I can clean up the face on the manifold, I'll just bolt it together dry.
Lambda sensors for the downpipes were ordered today once I'd confirmed that the current ones were 4 wire. The downpipes look long (front to back) but not that high so it looks like I'll be able to get them out without having the front of the car too high off the ground. |
