I've got a fault code which keeps popping up.
As above, it's 17538, fuel trim, bank 2, system running too lean. With the way the system works with faults like this, it has to happen a certain number of times before it bring on the engine lamp on the dash. By the time it's done this, the corresponding fault code 17536 is also there but it's always the other bank the is first with the fault code. I've been researching, checking lots and the obvious ones to look at are air leaks, air flow meter, lambda sensors etc. I've cleaned the air flow meter, checked the readings which register around 20g/s at tickover and 60-80g/s when you boot it. There is a spike when you initially boot off tickover which shows around 160g/s. Also, readings are similar when driving along. At 2,000rpm it's reading 18g/s and 60g/s when you boot it with the spike as above. I've checked all over the inlet manifold and found a small plug on the front which was very perished and splitting so I've replaced that. I've been running it on cheap fuel so this tankful, I've put super unleaded in. No change. The lambda sensors are all reading similar voltages, the cats are at similar temps etc. The one thing I've been watching is measuring block 32 which is 02S Adaption Maxims. From what I can see, Bank 2 running leaner than bank 1. See photo below. ![]() I'm still investigating but if one bank is running leaner than the other, that would suggest that the air flow meter is not the problem... Any ideas? MG |
I feel for you...a problem like this is annoyingly difficult to resolve as there are so many possibilities.
Could be as simple as a dodge fuel injector by the sounds of it....but I would try swapping things from bank1 to bank 2 a bit a time and see if there is any change in the fuel trim....
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
Lambdas are a common weak point, and on your AVP there are pre and post cat lambdas, doubling your chances of a tired one I guess.....
Swap em between banks like Ranj says and see if you problem moves.... ?
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Ok. I guess 185K miles is enough for any injector to be not at it's best.
I'll swap them over bank to bank and see if the problem follows the injectors. MG |
Blocked injector is an option but that would most likely throw up misfire codes as well unless its all injectors slightly blocked on that side and not just one. When you swap sides you will see if its that or something else. Try also swapping lambdas.
There is quite a difference between both sides which could mean there is breathing problem one bank getting more than it's fair share of air if is the same after swapping injectors and lambdas. You can also test lambdas on a bench while off the car with blowtorch and voltmeter.
Well the cause has been identified.
This last week the readings in measuring block 32 have been at their highest and then this evening, the engine died on the way home. It's the fuel pump that's died so it'll be running lean due to lack of fuel pressure. MG |
Recheck measuring blocks after changing pump as the difference is a bit high between banks -08 .. +10.9% giving total 11.7%. IIRC absolute value must be within -12.5..+12.5% but difference between banks no more then 6% on A8 and 4% on S8 engines
