Old 21st January 2009, 07:42 PM
Originally Posted by Norman Herring View Post
I have 10 year old 3.7 (front wheel drive) and carpets in n/side front and rear footwells are constantly wet any ideas on cause please? norman herring.
Norman,
welcome to the A8Parts Forum. Your car is a D2 model so a moderator will move this post to the relevant D2 section shortly.
Wet carpets are a common problem on the D2. Look here for one of the answers. There is also the chance that one of the sunroof drain pipes has perished and you have water running down the A pillar. Finally there is a through bulkhead hole in the passengers foot well under the ECU / TCU housing that may leak. I will try to find a link to a solution although Botang will probably have the link somewhere. Botang?
Mike
