Old 21st January 2009, 07:32 PM
Norman Herring
Guest
Posts: n/a
Default wet carpets
I have 10 year old 3.7 (front wheel drive) and carpets in n/side front and rear footwells are constantly wet any ideas on cause please? norman herring.
Old 21st January 2009, 07:42 PM
Norman,
welcome to the A8Parts Forum. Your car is a D2 model so a moderator will move this post to the relevant D2 section shortly.
Wet carpets are a common problem on the D2. Look here for one of the answers. There is also the chance that one of the sunroof drain pipes has perished and you have water running down the A pillar. Finally there is a through bulkhead hole in the passengers foot well under the ECU / TCU housing that may leak. I will try to find a link to a solution although Botang will probably have the link somewhere. Botang?
Mike
Old 13th May 2009, 02:23 PM
ulfilias ulfilias is offline
Hi There,
Had a little water in the passenger footwell, so while rooting cables blew the HVAC drain.
However, what causes some water under the *REAR* carpets ???
I guess most people don't notice when they have water as the foam backing is so thick it would never get through !
cya,
Lee
Old 13th May 2009, 05:11 PM
If water gets into the front passenger foot well in enough quantity it will migrate to the rear foot well where it pools. It can also get in via the air duct under the seat. Read this thread which is the one I promised at the start and forgot.
Old 19th May 2009, 04:54 PM
A8 Owner A8 Owner is offline
right ive took pass panel out and unpluged just bfore it goes into orange drain. other than put airline down it, is it easy to put the orange drain out and clean it out of car. IS it just a grommet style drain and if so easy to pull out and get back in????
Driver side is been a pain to get out as them plastic nuts that hold foot rest on r not been friendly LOL. 1 at bottm has come off just
the one in middle at side is the pain one. Take it thees just them 2??? as audi page doesnt show this side.
Old 19th May 2009, 05:43 PM
Here is your tunnel.....
The 2 orange drains come out in the tunnel behind some heat shielding and a lot of sound deadening. there are channels in the foam that let the water out. The orange drains can just be pulled out but there is no need. if you have low pressure air just blow them through. Blow upwards and if there is a blockage stand by for a cleaning job inside!!!! better to use a thin wire and clear the pipes.
Old 21st May 2009, 09:40 AM
*SCARED*
Thats more or my d2 innards than i ever wanted to see !!!
I'm sure there is something important missing....
Old 21st May 2009, 12:34 PM
Originally Posted by ulfilias View Post
*SCARED*
Thank god u noticed thought it was just me who noticed this didnt have the washer bottle
Old 26th November 2009, 11:12 AM
badger7777
Guest
Posts: n/a
Just started to unblock my aircon drains - pasenger side trim removed, pulled off the orange pipe but wasn't prepared for the deluge of water! Think there must have been well over a pint in there! Managed to quickly get the orange pipe back in place before getting a jug to catch it all!
Is it necessary to repeat the operation in the drivers side too or is the condensate tray linked?
Old 26th November 2009, 12:49 PM
I'd do the drivers side too, just to unblock that, should reduce the chance of a reoccurrence.
