Old 10th June 2012, 09:30 PM
BOGOF??
Old 10th June 2012, 09:42 PM
47p2's Avatar
47p2 47p2 is offline
Special offer... £49.95, have 2 scans get 1 half-price (sure that'll appeal to the 'Northern' contingent).. Could possibly even supply a voucher
Am oot
Nite Blue 3.0L SE Quattro
Old 10th June 2012, 10:22 PM
Thanks for that. I am sure it will clear the next time I get to scan and clear it.
When you've done any work on the xenon range you must run the calibration before it will be happy again.
Each of the two xenon range sensors basically generate a 0 to 5v output depending on their position, and thus reports to the ECU the level-ness of the car.
Every sensor will be slightly different, thus when a sensor is connected up for the first time, you need to run through the basic settings to calibrate the module to 'level ground'
See here:
http://www.ross-tech.com/vag-com/car...alignment.html
Old 11th June 2012, 01:46 PM
These things are never simple eh! but thanks for the tip. it does make sense as there isnt a "centred" (i.e. "level" position) on the sensor as that needs to be determined by calibrating it as you have described.
Old 11th June 2012, 02:44 PM
Happy to let you borrow my cable for a couple of days.
Old 11th June 2012, 03:59 PM
Thanks for the offer Richard. When you attending on the Laird's sunroof next?
Old 13th June 2012, 08:18 PM
Strange to say, when I drove the car this evening, the warning light did not come on and everything was as it should be!! I havent done anything which could have changed anything apart from the fact that the car was sat on the drive for 3 days wothout being driven.
Old 13th June 2012, 08:24 PM
Try a bumpy road and see what happens... Maybe it does self-calibrate then.
Old 13th June 2012, 08:26 PM
I did. Just came back from Dumbarton and did 80mph over the backroad almost getting airborne off the humpback bridge (SWMBO wasnt happy....) The warning light stayed off. (hers went on!!)
Old 13th June 2012, 09:46 PM
I am sure it must have been KPH easy mistake to make
