Old 13th June 2012, 01:53 AM
madcjd madcjd is offline
Fault resolved
Old 13th June 2012, 03:56 AM
Sounds like the wiring or Connectors from/to Transmission Control Module (J217) are faulty in some way. That;s where I'd start. You can check in VAGcom - Measuring Value Block (MVB) 125+
Could be a fualty TCM possibly otherwise.
Old 13th June 2012, 06:02 AM
Is the VAGCOM connecting to TCU?
Old 16th June 2012, 03:15 PM
OK
Old 16th June 2012, 05:29 PM
That's results from ECU and ABS. Is VCDS not connecting to TCU? Do you get no connetion error when trying to read TCU?
Old 16th June 2012, 06:00 PM
Certainly those codes point to the TCU. It's listed under 'auto-trans' on VCDS (Though you probably knew that).
Old 19th June 2012, 01:45 PM
I'm quite new to VAGCOM. I do I connect to the TCU?
Old 19th June 2012, 03:42 PM
Click the 'auto trans' button when you are in the main menu.
Old 28th June 2012, 09:51 PM
Nollywood's Avatar
Possibly water ingress in the TCU / connector, or a broken wire.
