Old 10th July 2012, 08:31 PM
think_or_thwim think_or_thwim is offline
Default Reverse Sensor Not working!
I'm not sure how it works. Should it beep when I engage reverse or only if I am about to hit something.
Scanned the car and no fault found. Could the fuse have been removed? or any other help?
TVM
Old 10th July 2012, 08:41 PM
it should make one beep when you engage reverse and the green light on the button comes on then it only beeps when getting into range of any obstructions, getting faster the closer you get
Old 10th July 2012, 08:43 PM
On the D2 it should beep when you select reverse.....
Then start to beep intermittently as you get close to something and a constant when you are very close.
A crunching sound happens when you get too close
Old 10th July 2012, 08:51 PM
remember it will also bleep from front if you get too close there as well
Old 10th July 2012, 08:55 PM
...being pendantic, that would be a real upgrade worth paying for. Mine only makes a crunching sound when I've hit something.
Old 10th July 2012, 08:58 PM
Only on a facelift though.... Seems accuracy is paramount here...
