Still worth it in Glasgow... keeps the edge off the heat for those 3 days we get the sun
![]() The Laird will let us know soon enough when we get round to finishing the job off.
On that note when as i need you vag test as still parking sensors let me now thanks
Men have feelings too. For example we feel hungry..... |
![]() ![]() My solar no longer works as i found out the other day when i got in it. Where should i be looking for the relay is it in the pass footwell? It's only when it stops you realise how good it is eh?
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. Last edited by Dezzy; 15th August 2012 at 09:39 AM. |
![]() Last edited by tintin; 15th August 2012 at 03:57 PM. |
Thought I'd post some pics of the spare solar panel I'm stripping ready to fit to my car, to go with Ian's excellent pics of the wiring side of things. Will add them as I go, along with some simplified info on fitting.
These are the clips you need to release to push the fabric internal cover back - they only need finger pressure to release them and there's one each side on the front edge. Sunroof needs to be slightly open to access them and you can then slide it back out of the way ![]() This is how I got my panel - the whole thing complete with frame! At least it was protected in transit ![]() With the interior trim pushed back this is what you see on a solar equipped car. This is the offside one - it appears when it was assembled they weren't all that careful as the wire is bent and the insulation is slightly damaged. Probably doesn't matter but will check it properly before fitting. ![]() Passenger side view ![]() The 'inside' view of the sunroof trim panel clips so you can see what it is you're unclipping - I just removed this one so I could see how it goes together - I don't need it as it's a different colour to mine ![]() ![]() Trim panel out and this is the inner workings of the solar panel itself ![]() With the roof panel shut, there are a total of 6 T25 torx screws to remove. 1/4" socket set gave plenty of access. I inverted the panel and undid the screws and lifted the frame off as I was working on my own and didn't fancy dropping it! ![]() These are the remaining bits you need from the donor car ![]() Close up view of the bit that actually does the work - the rectangular block is the contact between the solar panel and the wiring in the frame ![]() E-markings on the glass - E11 is UK and E1 is Germany and Reg 43 relates to laminated glass ![]() Top view of the panel off the car ![]() Quick clean with Fast Glass later and the top side looks like new ![]() Any tips from the detailing fetishists on how to clean the seal around the sides of the panel? It's more of a felt material than the rubber on the non-solar panels and I nearly fell off my chair when I priced up a replacement!! Thought if it was cheap and available I'd swap it anyway but that ain't happening ![]() That's progress so far - will take some pics of the rails as I get them off. Any tips from anyone that's done it before? It looks like the wires go through the frame so no idea if there's a connector I'll see when I've undone the torx screws, or will I have to cut and rejoin the wiring? Adrian
I used Turtle Wax Restorative Black Bumper & Trim Wax on mine Adrian, came up really well and seems to be lasting well too
Audi S8 2015, Daytona Grey Maserati Granturismo 2008, Metallic Nero Carbonio Last edited by briang9; 28th October 2012 at 12:25 PM. |
A steam cleaner and a small brush will bring the seal up like new
. Nite Blue 3.0L SE Quattro |
#30
Manufacturing info from solar panel
![]() Offside wiring - just cable-tied to sunroof mechanism with some anti vibration foam round it ![]() ![]() Nearside wiring ![]() ![]() Sunroof motor removed off donor assembly - think the wiring plug should sit in the plastic clip that the wiring is sitting in in the picture ![]() Frame part number details ![]() Wiring ready for removal ![]() Contact point removed from end of sunroof rail - there's is nothing to disconnect the wiring at this end ![]() ![]() Having established there's no other way to remove the wiring, this plug needs to come apart. Remove the purple cap with a screwdriver and insert a screwdriver up the end of the plug to press the metal tab on the wire down and pull out the back ![]() Contact points top and bottom ![]() ![]() This is the tab you need to free off to get the wires out of the plug ![]() I didn't take any pics of removing the rails, but basically it's 7x T20 torx on each side and the roof mechanism needs to be more or less right back so the panel mounts are out the way and they can be lifted out. The screws have evidence of threadlock on them and are barely even finger tight - I had a bit of a play around and it's very easy to over-tighten them and the roof mechanism will then feel tight if you operate it by hand (4mm allen key in motor) Given the suggested torque for the screws holding the sunroof panel on is 4.5Nm I'd expect the rails don't need to be any tighter than that. If you have it some threadlock probably won't go amiss, particularly on the rails. I've wrapped the solar panel in bubble wrap for now and won't be fitting it until I have some help available to lift it into place. In the meantime I'm hoping to grab an anti-dazzle mirror as wiring that in properly will involve removing all the same bits of trim as getting the sunroof wiring into place! Adrian
