Old 7th August 2012, 09:50 PM
richardracer richardracer is offline
Default ECU Fault - what do I look at next please?
Hi Folkes,
I have finally got my VCDS and got these engine codes. Can someone tell me where to look for what to do next
Thanks
Richard
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 96550 km
Time Indication: 0
Date: 2012.02.07
Time: 00:00:47
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 6.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.684 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 98873 km
Time Indication: 0
Date: 2012.05.05
Time: 12:35:39
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 25.0°C
Absolute Pres.: 990.0 mbar
Voltage: 10.668 V
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 8th August 2012, 05:55 AM
18055/P1647/005703 - Check Coding of ECUs on Powertrain Data Bus
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Coding of Powertrain related Control Modules wrong/incomplete
Possible Solutions
Brake Electronics
Check Powertrain Control Module Coding, especially check the Airbag Control Module Adaptation Channels 050 & 051.
18331/P1923/006435 - Please Check DTC Memory of ECU Number 2
Possible Symptoms
Possible Causes
Fault Code(s) stored in Engine Control Unit 2
Possible Solutions
Check/Fix Fault Code(s) in Engine Control Unit 2
Special Notes
This fault code is a note since the system it is stored in interacts with the Engine Control Unit 2 and due to a fault code there it may not be fully functional.
