Old 8th August 2012, 08:13 PM
47p2's Avatar
47p2 47p2 is offline
Originally Posted by RanjS8 View Post
The piston is connected to the crankshaft by two bolts and there is a metal sleeve between the piston and the cranshaft.
The metal sleeve will be the big end bearing.
Nice work there, always gives a good feeling when you are doing your own spannering.
On the rebuild the best advice is to take your time and check, check and check again before stitching everything up
Nite Blue 3.0L SE Quattro
Old 8th August 2012, 09:16 PM
Impressive effort Ranj, I dont think I would have the courage to take an engine appart.
Old 8th August 2012, 09:23 PM
And no bringing all the bits with you to Germany!!
Old 9th August 2012, 06:47 AM
sloss's Avatar
sloss sloss is offline
You are venturing into the unknown....
You need to be careful on the rebuild to get the piston the right way round - it may be obvious but still something to watch. You will need a piston ring clamp to get the rings into the bore with no damage, plenty of oil and a wooden hammer shaft to tap it in.
The Big End Shells should have been kept with their piston so they go back onto the same Crank Journal unless they are scored and need replaced.
You are attempting a skilled job here so make sure you read the bumph and follow it in detail. I've rebuilt a lot of engines but not one of these, however it may be that new bolts are specified for the Bigends as they could be stretch ones or it could have nylock nuts which should be renewed as a matter of course - all this info needs to be known up front as does the torque for all bolts/nuts and the order of tightening.
Loads of little things to get right.
Good luck although luck shouldn't be a factor really
Old 9th August 2012, 07:20 AM
RanjS8 RanjS8 is offline
Default Big end shells
Thank you...I appreciate the advice...I figured that big end shells and bolts are specific to a piston so kept them seperate in the Morrison sandwich containers u see beneath the piston....but I certainly do have some reading to do before I start putting the engine together.
Old 9th August 2012, 07:44 AM
gninnam gninnam is offline
Very brave and great work so far
Hope it works out for you (plus all the knowledge you are gaining)
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 9th August 2012, 08:32 AM
Very impressive Ranj, keep up the good work
