Old 12th August 2012, 08:49 PM
Dan McBoost Dan McBoost is offline
Exclamation Lowering links - Who has them?
I am interested on putting these on my D3, but before I buy a set can anyone post a photo of how their car sits AND the length they used for the links?
Thanks in advance!!
Dan
(yes I still have my D2 (and others))
Old 13th August 2012, 08:28 AM
Not seen anyone use physical bits for lowering a D3, just adjusting the suspension with VCDS for up to an inch lower.
Old 13th August 2012, 10:19 AM
See the thread below for some physical lowering assistance, I posted a PDF a while ago about it on page 2 or 3 -
http://forum.a8parts.co.uk/showthread.php?t=2460
Old 15th August 2012, 07:28 PM
I have looked at that topic a bunch and did see the PDF.
I have seen in the past a PDF of the installation of them, and cannot find it now.
I am trying to gauge a few things and want to be prepped completely before I order the set up (or make it if I cant find a good deal).
Old 15th August 2012, 07:35 PM
Ah ok - installation instructions attached - hope this helps!
File Type: pdf Installing Suspension_Lowering_Kit.pdf (850.2 KB, 774 views)
Old 15th August 2012, 07:37 PM
Have you installed these on a D3 yet?
I would love to know the ball size. maybe I could make a set by simply using McMaster.com :O
Old 15th August 2012, 08:27 PM
Ah... looks like they just adjust the length of the sensor arm, so essentially the same thing as the VCDS lowering as that re-calibrates rather than fooling the car that it's at normal height.
