A8 / S8 Generic Posts All other useful info |
Thanks for this explanation.
Second point makes sense for me. First point I still struggle to fully understand as I thought performance of rings doesn't depend on amount of oil under them. How sensitive Audi V8 engines are for oil overfill? 4.2 / 3.7 engine normally needs 7.5-8 liters of oil and if I fill 9 liters, is this an immediate disaster? Any horror stories?
I'd rather drive on left |
I owned a 944 for a couple of years back in my (much) younger days. Took it into the Porsche dealer to have a service and two weeks later I noticed a pool of oil on the garage floor. I checked the oil level and was horrified to notice it was well over the high mark on the dipstick. I called the dealer and explained to the service manager that I had a rear crankshaft oil leak and asked if overfilling it with oil could have caused the problem, to which he replied that overfilling puts lots of extra pressure on engine seals and most certainly did cause it to blow the seal. He wasn't so happy when I told him that they had just serviced it and overfilled it and therefore I was holding them liable for repairing the leak. They did agree to replace the faulty seal and filled it to the correct level once finished
. Nite Blue 3.0L SE Quattro |
Thanks 47p2, interesting horror story with a good end
![]() Do you remember how much higher was the oil level on dipstick? Was it like two times higher than the distance between max and min?
From memory it was around 1" above the high mark
1 inch above high mark is a lot
Which is why it caused the seal to rupture.
The modern method of checking the oil level is to have the engine hot and switch it off and leave for 5 minutes, then check the level. I find this completely inaccurate and always check it when cold, I remove the dipstick and let the dip-tube drain clear, usually around 15 minutes to clear all the residue and then insert the dipstick and take a reading, this gives a far more accurate reading without any pick-up of oil from the tube marring the accuracy. I always make sure the level on the dipstick is about 2mm below the top mark when cold, this allows for any expansion without going over the mark
. Nite Blue 3.0L SE Quattro Last edited by 47p2; 13th August 2012 at 04:41 PM. |
I carried out a little experiment today on the Mercedes.
Engine cold, removed dipstick and wiped then took a reading, note how it shows to be at the top mark ![]() My theory is some of the oil stays on the dipstick tube between the end of the tube and the end of the dipstick, when you remove the dipstick it drags the oil from the tube onto the dipstick giving a false reading. If you remove the dipstick for 10-15 minutes this allows the tube to clear and give an accurate reading Engine cold, dipstick removed for 15 minutes, then took a reading, this I guess is the most accurate reading. ![]() After a 380 mile journey I removed the dipstick, wiped it and took a reading, it shows well over the top mark ![]() So I left the dipstick out for 10 minutes to allow the tube to clear and took my final reading which shows the level to be bang on at the top mark ![]()
. Nite Blue 3.0L SE Quattro Last edited by 47p2; 14th August 2012 at 07:33 PM. |
