Old 25th August 2012, 01:39 PM
maglite's Avatar
maglite maglite is offline
Default Is this the correct AMI that I need for a D3?
Hi, I was just preparing myself for any additions I would like to add after I buy a D3. Am I right in thinking this is the correct bit of kit for a 2005/2006 model?:
http://www.ebay.co.uk/itm/Audi-Music...ht_2053wt_1397
Thanks
Old 25th August 2012, 02:01 PM
Certainly looks to be the job
Old 25th August 2012, 03:02 PM
litlle bit expensive, but does have the optical cable , useful if you want to keep the cd changer
Old 25th August 2012, 05:35 PM
maglite's Avatar
Ok thanks. I did check previous threads, but wasn't quite sure. I'll see if TPS can give me a better price.
Also on the D3 models with TV Tuner. I was wondering if anyone would know how hard or easy it would be to add an aux source. I recall reading a thread about a triple phono cable that has to be connected. Is the location in the boot?
It looks something like this:
Old 25th August 2012, 06:05 PM
its easy , just a bit fiddly on the left side compartment in the boot
undo the two bolts holding the dvd nav drive and drop it down, then add that cable in to the correct pins of the big 20 pin connecta on the tuner
worth doing both inputs while your there though
Old 25th August 2012, 08:19 PM
maglite's Avatar
Ok thanks, that's brilliant. I think after the AMI and the AUX video inputs, I'd be happy with the ICE. I'll see if I can run the RCA's to the compartment under the arm rest.
Old 25th August 2012, 08:43 PM
can do , depends on what you want to plug in, for simple video you are better of installing something like the veba dvd and sd/usb device in the boot and using remote
Old 25th August 2012, 10:04 PM
Definitely with getting the 2 inputs and the output too while you're in there, just in case.
Old 25th August 2012, 10:16 PM
if your putting all 3 in though, all connector cables are not made equal, some use thicker wires than others which makes getting the connector cover back on afterwards really difficult.
Old 26th August 2012, 07:47 AM
The kufatec ones are slightly expensive, but reasonably thin from memory.
