Old 25th August 2012, 06:41 PM
Mutley Mutley is offline
Default Rear OS Caliper
Fully working please, preferably one where somebody hasnt forced the piston back
Old 25th August 2012, 06:53 PM
47p2's Avatar
47p2 47p2 is offline
The piston has to be pushed back when fitting new pads
Nite Blue 3.0L SE Quattro
Old 25th August 2012, 08:29 PM
I know, found out today, the previous owner had changed the pads, I checked this when visually checking the car over prior to purchase, the pads are 8mm thick but vagcom only reads 3mm and is throwing the pad warning constantly. Vagcom won't let the setting be over ridden so I'm assuming the pistons skipped a thread or something causing the misread ?
I can only assume the previous owner pushed\forced the piston in withou resetting
Only had the car x3 weeks and this is the first thing I've found so if that's all there is I've got off lightly I think
Old 25th August 2012, 09:30 PM
47p2's Avatar
The piston can't skip a thread. Why not switch off the EPC using Vag-com then remove the pads and push the pistons back in and reset and see if that clears it
Old 25th August 2012, 10:05 PM
There is a procedure to re-calibrate the read brakes, it's not as simple as just changing the figure from memory.
Old 25th August 2012, 10:12 PM
47p2's Avatar
I wasn't sure how it's done on Vag-Com Richard, I used my reset tool to do mine.
Here's the Ross-Tech page for how to set it Click
Old 25th August 2012, 10:57 PM
Ah, I have a cable on the way so when it arrives I'll be doing it myself, cheers for the guide i'll, I have a friendly garage that allowed me to use there vagcom today and I did do the reset but I didn't disable the epc, hence I didn't resolve it assuming it was a calliper needed.
Old 26th August 2012, 08:26 AM
47p2's Avatar
The caliper and the EPB are two separate items
