Old 5th September 2012, 07:00 AM
SilverS8 SilverS8 is offline
Exclamation Power steering issue (rack worn out?)
Hi all.
I recently replaced all control arms except the tierod ends(as they seemed pretty good and the fact that it triggers a new wheel alignment)
All has been goo until the other day. Suddenly i have a "free" spot when turning the steeringwheel at standstil and low speeds. I can move the steeringwheel about 3-4cm without the wheels moving(or at least its minimal movment)
All control arms checked to rule out any loose parts.
To clarify:
-Engine off: Everything is solid, no slack/free spot
-Engine on and speed under 20 mph i can feel this free spot
-Over 30+ mph it all feels perfect.
I would think that f the rack is worn out i would feel the free spot when engine was off?
There is no noise,leaks or anything that would explain why this has suddenly happened.
Any info would be appreciated... Its MOT time within the next 3 weeks...
Jan
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 5th September 2012, 07:32 AM
47p2's Avatar
47p2 47p2 is offline
Any clunking noises when this happens?
Nite Blue 3.0L SE Quattro
Old 5th September 2012, 08:51 AM
No noise of any kind..
2000 Silver S8
Old 5th September 2012, 09:19 AM
47p2's Avatar
You need to get under and see where its coming from
Old 5th September 2012, 01:38 PM
Is it moving freely or do you feel springy resistance that returns it to middle position of free spot? There are springs that centres it. As you turn steering wheel spring is slightly compressed and opens hydraulic valve for power assistance. If there is no power assistance like with engine off and high resistance on wheels like on standstill you can turn steering wheel by quite a bit overcoming spring resistance before wheels start turning but as soon as you let it go it returns to centre position of free spot. If the springs are getting weak, stuck or broken this would allow for more free movement. Or if the power assistance is getting weak you would feel it more when driving. Can't really judge situation without having a feel myself but if it appeared suddenly it would suggest that something is faulty.
Old 12th September 2012, 12:59 PM
I'd be having the car tracked after replacing all the arms
