Old 5th September 2012, 09:48 AM
sloss's Avatar
sloss sloss is offline
Originally Posted by wiingg View Post
I take it that means pulling the fuses one by one and testing or is there a quicker method
Using a Mulitmeter set to the beeper alarm just touch each visible end of the fuse while it's in position, it should beep: no beep = duff fuse/connection.
Don't hold it on for long as, depending on type of meter, you may complete the circuit and have current going through the meter.
As you are checking a small part within a circuit there will be no shorting or problem caused elsewhere
