Old 21st September 2012, 12:56 PM
Default FL Instrument Cluster Swap with no SKC's
Can this be done?
I don't have the 4 digit pin for the current cluster, and I wouldn't think that a replacement cluster wherever its sourced from will come with one either.
I guess the pin number would need to be extracted from both clusters using something like VAG-Tacho, but can the pin number of the replacement cluster be extracted whilst connected to the car it's not currently paired with?.
Old 21st September 2012, 04:56 PM
cerips cerips is offline
You just need the SKC for the used cluster according to the Ross Tech wiki
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
Old 21st September 2012, 07:20 PM
You will need login for new instrument panel or you can solder memory chip over from old cluster.
