Old 22nd September 2012, 08:53 AM
Mutley Mutley is offline
Default Swapped heating controls
Here's a weird problem, driving to work on Thursday noticed changing the heating controls that the car now thinks its left hand drive, ie changing seat temp for me it says passenger. From what I can make out its just the wording
Any ideas ? Now that I've noticed I'm not sure if it was always like that ????
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
Old 22nd September 2012, 04:52 PM
Did you do an MMI update recently?
It needs recoded with VCDS to be told it's RHD... It's just the label that's wrong. Mine did the same.
Old 17th October 2016, 09:05 AM
mmarksx19 mmarksx19 is offline
Resurrecting an old thread but mine has done this since I bought it (I assume at some stage the HVAC control unit was replaced). Any adjustments to the drivers side say 'passenger' and vice versa. The arrow points the right way and the adjustments work on the right side, it is just the 'Driver' and 'Passenger' titles that are wrong.
I have VCDS, where can I look to swap these round?
Thanks!
Michael
2007 A8L 3.0TDi
Old 17th October 2016, 09:09 AM
Add the values of 1, 2 & 3 together and code that.
Note down your existing code first! (probably need to just add 16384 to your current coding value for RHD)
Breakdown of code "1" (optional extras):
Code number (for conversion if encoding is not performed in Guided Fault Finding)
1
No assignment (always "1")
2
Vehicle with auxiliary heater
4
Vehicle with heated windscreen
8
Vehicle with heat-absorbing glass
16
Vehicle with rear Climatronic control unit -E265-
32
Vehicle with Audi one-touch memory (Fingerprint)
64
Vehicle with rear roller blind
128
Vehicle with sun roof with solar cells
Breakdown of code "2" (country version and vehicle model)
256
Vehicle for USA (and Canada)
512
Vehicle for Japan
1024
Code not used at present (intended for cold climates, e.g. Scandinavia)
512 + 256
Code not used at present, intended for hot climates, e.g. Australia and Saudi Arabia (introduction pending) - The control is set up largely as for the USA.
2048
Vehicle with diesel engine
4096
Vehicle with 8-cyl. engine
8192
Vehicle with 10-cyl. engine
4096 + 8192
Vehicle with 12-cyl. engine
16384
Right-hand drive vehicle
32768
Vehicles with stretched body
Breakdown of code "3" (rear seat heating and ventilation, seat covers and glazing):
65536
Vehicles with rear Climatronic control unit - E265- with control for heated rear seats but without control for ventilation for rear seats
65536 +131072
Vehicle with control for heated rear seats and with control for ventilation for rear seats
26214
Seat design (seat covers in vehicles with seat ventilation) - Seat cover version "1".
524288
Seat design (seat covers in vehicles with seat ventilation) - Seat cover version "2".
524288 + 26214
Seat design (seat covers in vehicles with seat ventilation) - Seat cover version "3"
1048576
Vehicle glazing
0
Coding for vehicles with 8-cyl. engine and heat nsulating glass. - Actuation of heated rear window
stays on even at temperatures below 0 °C but time-limited depending on ambient temperature between 2
and 20 min).
2097152 + 1048576
Vehicle glazing - Coding configured with heat insulating glass with infrared characteristic line. - Introduction of this version pending. - Intended e.g. for PR no. "VW8".
Old 17th October 2016, 09:16 AM
This can be changed from the MMI
Go to the MMI hidden menu (car+setup)
Go to Diag Settings > Car Menus Maske
Uncheck Linkslenker (this is the setting for left hand drive vehicles)
Restart the MMI
Climate control should be back to the settings for a right hand drive car now!
Matt
Old 18th October 2016, 08:01 AM
Restart the MMI
Tried this method as it seemed far simpler and it worked a treat - many thanks. I didn't even need to restart the MMI as there was a 'Save and accept changes' option at the bottom of the list.
Now my Driver & Passenger labels are perfect. Thanks again. Can't believe how long I left it before asking you experts. I feel like I've fixed something!
2007 A8L 3.0TDi
