Old 13th May 2012, 08:13 AM
Duplicate post from long ago. Removed duplication.
As noted in another thread today, a company in Leith do make an adapter to use the OEM TV aerials with add-on equipment.
I will report on progress here; feeing optimistic.
Old 20th September 2012, 01:35 PM
Well I've ordered one of those "phantom" aerial adapters from the guy in Leith.
Got a good price and ordered a pair so that I can (worst case) mess one up, or upgrade to a diversity tuner later if it works well.
Good price is partly because they have all been built so no options on connectors, if you don't want F-connectors (I don't) it's DIY to adapt appropriately (my tuner is SMA). I also think it's maybe "end of line" so reduced "to clear".
Meanwhile I have a question that hopefully someone can answer...
The tuner has 4 aerial connections, rather small. The seller said he thought they were SMB and his lead had those connectors on.
He wasn't sure why 4 though and thought maybe 2 were for the radio which seems a bit unlikely - isn't that a separate unit?
Can anyone clarify?
He also wasn't sure if they were "active" (powered) TV aerials in the D2. His leads do have the capability of passing +5V up them IF the tuner supplies it. My new DVB tuner doesn't but he sells some that do (optionally). Does anyone know the answer to that as well?
So, 2 questions that hopefully someone will know the answer(s) to:
Why 4 aerial connectors on the Analogue TV tuner and what are they?
Are the aerials "active" requiring a power supply up the aerial (usually 5V)?
Old 25th September 2012, 12:35 PM
Not good news.
The cables supplied (maybe he sent the wrong ones) don't fit.
They have a MALE push-fit connector on on end (to fit onto the factory-installed aerial leads) and an F-connector on the other (to go to a new DVB-T tuner).
The Analog TV tuner has a female socket and the incoming leads have male connectors on. They are push-fit but look a bit bigger - anyone know what they are exactly?
Old 25th September 2012, 01:29 PM
Well we've spoken and he's as confused as me, as he was sure the Audi analogue TV loom was an SMA connector and he'd fitted one - maybe a later model?
Anyway, he's found another lead design with a slightly larger push-fit connector and sent me a picture - it certainly looks plausible so he's posting it and I'll send the others back.
So we'll see what the result is with this type, it too has an F-connector on the other end so is presumably an aerial lead of some sort.
Old 25th September 2012, 01:45 PM
Are these possibly MCX connectors?
Old 25th September 2012, 02:01 PM
Can't help I'm afraid, but watching with interest as its a mod I want to do.
Old 25th September 2012, 02:05 PM
You have type A tuner - which did have those odd connectors, and sorry, cant help you with what they are exactly.
The Type B analogue tuner from late 2000 onwards had the SMA connectors on it.
When I did the D2 project car a few years back I removed all the old Type A tuner cabling and retrofitted Type B aerials and cables just to be on the safe side so when I went digital I knew it would work...
I'm thinking lopping off the connectors and re-ending with SMA could be a good choice....
Old 25th September 2012, 02:12 PM
There's not much room in there and there's no slack in the cables.
They might be "odd" but I'm sure they're a "known" type, I can't believe Audi had them specially made.
I do recall a similar problem with the GPS aerial (same connector?) and in the end I did splice that, but there's loads of slack in the boot lid to play with so less of a problem.
Old 25th September 2012, 02:17 PM
Ian, having done that can you comment on:
1. Are the aerials passive or active (powered)?
2. Where (roughly) are the 4 I have and which would you use if limited to 1 or 2?
Old 25th September 2012, 02:48 PM
does this page help?
http://www.dabonwheels.co.uk/Car_rad...ification.html
