Old 26th September 2012, 08:52 PM
Just out of interest, what phantom aerial are you planning to fit and do you have the leads?
Reason I ask is that as a result of my own failed attempt (SO FAR) to "phantom" the PF OEM "unidentified connector" TV aerial into my new DVB-T unit I have some spare leads that I was going to send back for a refund.
However, they may be suitable for the FL model TV aerial leads as they're different (more "standard") and the vendor was convinced they were correct as he had fitted some.
PM me if you are interested or want details.
It might be worth meeting up at some time to see if there is a use for them in mine then. He told me originally that he would make the aerials up to suit my particular situation but I just hadn't got around to it yet and it sounds like the options are more limited now
Old 26th September 2012, 09:08 PM
I really don't want to have to cut these rather short cables and do any soldering inside the boot.
As a side note, they're coax - I'd expect most coax connectors to be a crimp, no soldering involved...
Old 26th September 2012, 09:17 PM
Ian, thanks for that thread link it was REALLY useful info.
I think I did once glance at that thread, but as it's primarily about fitting an RNS-E into a FL car I didn't get far into it.
Some things I've identified already from that thread:
- You found a +12V ignition feed (black/green) to the TV tuner. I need that.
- The diversity/aerial setup for your "A" tuner is probably the same as mine with that aerial "diversity" unit inside the cabin.
- I reckon that unit is actually just a filter, splitting radio and TV signals off into their respective directions. If it was doing diversity stuff why have 4 leads going on to the TV tuner?
- Also it looks like the aerials are powered, but not "up the cable" from the TV, so I can leave them alone and presume (hope) they still work OK.
- That aerial unit behind the rear seats looks like it could have a more common type of connector for the TV aerials so if necessary I could tap in there, though I don't want to. Or is it that connector type you can't identify at that end as well?
So, overall I'm feeling more positive. If only I could identify those weird connectors.
There's convenient power, I know where to run the cables I need and the existing aerial(s) should work.
On the down side I'm probably going to have to hack into the aerial cables in the boot and reterminate.
Old 26th September 2012, 09:29 PM
The web site implies that, but when I spoke to him the other day he basically has just one type in stock of (short) male-male lead which is SMB at one end and F-connector at the other and fits almost all systems (but not my old A-type tuner leads).
I sort of got the impression that he might have had a batch made up some time ago and the bespoke variations were not an option now.
I imagine you could buy such leads on eBay these days quite cheaply delivered directly from China.
Old 26th September 2012, 09:30 PM
From memory, they are the same wierd connections on the unit behind the seat as the tuner itself.
Its not a massive job to change the loom from old to new. Just back seats parcel shelf and D pillar trims off..... a8parts might be able to sort you a kit.
Car aerials, especially on the move, are nothing like as good as your huge home antenna so you cant afford to have any dodgy wiring or poor connections or you'll likely end up with nothing of much use at the end of it all....
My D3, with factory aerials and factory tuner only gets acceptable reception in city and town centers generally. The rest of the time its next to useless as the audio is forver cutting out. I miss analogue, it was far more useable in a car.
Old 27th September 2012, 08:50 AM
I wouldnt ever use just 1 or 2.... There are 4 for a reason
In which case this tuner (about £150 delivered) might be of interest to some: http://www.lcdgps.com/4-diversity-4-...t-receiver-car
Old 27th September 2012, 04:38 PM
Ian, what did you do with the old style "diversity unit" that you took out and replaced?
I'm thinking I could take one of those, keep the external TV connectors but otherwise gut it completely, and make a small box that would have the 4 weird connectors on one side and 4 more "normal" ones on the other, connected 1:1 internally. (a giant 4-way parallel aerial adapter)
Well within my capabilities and much preferable to hacking cables behind the trim in the boot.
Old 27th September 2012, 07:01 PM
thats a great idea!
Old 27th September 2012, 09:32 PM
Er, no idea...... !
That was 2 years + ago, so I'd guess like most of my spare bits it either ended up in the vast recycling portfolio that be a8parts, or more likely the bin as it had zero value to me....
I'd be suprised if a8parts couldnt dig one out for you at a reasonable rate.....
Old 27th September 2012, 10:43 PM
I've asked (by email).
Can't imagine they'd be worth much more than the postage.
