Old 28th September 2012, 11:20 AM
Dave McB Dave McB is offline
Question
Yep, carpets have been out and dried for weeks - actually REALLY dry
Psyche - i have the same issue lol
Architex_mA8tey - also done this while car was parked on a hill - surprisingly managed about 500ml of water out.
Generally the car gets steamier if its left on auto - i wondered if it was better to have on a certain setting...
Old 28th September 2012, 11:26 AM
In that case maybe you have a problem with the aircon dehumidifier? Not sure how you check that.
Old 28th September 2012, 11:37 AM
47p2's Avatar
47p2 47p2 is offline
Possible the receiver/drier needs changed, not expensive but will require the system to be recharged once fitted
Click
Nite Blue 3.0L SE Quattro
Old 28th September 2012, 01:25 PM
Thx guys - that could be a shout.
Il get looking into it just now
Old 28th September 2012, 02:48 PM
Thought the drier was just for the aircon fluids which never actually come into contact with the humid air?
Old 28th September 2012, 02:57 PM
47p2's Avatar
It keeps everything inside the system clean and working properly
Drier or Accumulator: The drier, also known as the receiver-drier, is sort of the safety catch for your system. The compressor is only supposed to compress the gas form of your refrigerant. However, there's always a chance that some liquid could make it back that far. The drier catches this liquid before it can damage your compressor. Since even the tiniest leak or careless installation can introduce water moisture to the system, the drier absorbs this chemically, using what's called a dessicant (similar to that packet of "DO NOT EAT" that comes with electronics). The drier also has a filter that catches any gunk that might be in there.
Old 28th September 2012, 03:15 PM
Yup..but it's 'sealed' so the steam you see is more likely to come from the matrix where it's not drained properly.
Old 28th September 2012, 03:16 PM
47p2's Avatar
Yes but if the system is not working correctly it won't keep the interior clear
