Old 28th September 2012, 12:25 PM
Unhappy
it looks like the aerials are powered, but not "up the cable" from the TV, so I can leave them alone and presume (hope) they still work OK.
Or maybe not....
I've just checked the aerial sockets on the tuner and as soon as the RNS is turned on there is +10V on the central connector of each socket.
Most systems use 5V though so not sure of the implications of this.
While delving around I totally removed the tuner and will have a look inside - maybe I can remove the sockets from there (they're useless in situ) and use them for a DIY adapter?
Edit: Not in any practical way, they're rather too integrated into a metal-caged unit that has no obvious way of removal or entry.
Old 28th September 2012, 02:01 PM
You found a +12V ignition feed (black/green) to the TV tuner. I need that.
Which seems to be black/blue on my car. There isn't however any +12V that comes on when the RNS is switched on with the ignition off.
So, short of installing a relay or switch I'll need to have the ignition on to watch TV when parked up.
I also found a description of the multi-pin video connector on a German web site. This might enable the old TV tuner to be dispensed with entirely, feeding the DVB-T directly to the RNS? NF = Niederfrequency = Audiofrequency
(Though the RNS seems to detect the tuner via the 6-pin power lead, unplug that and it's N/A)
On the plus side I've fixed my hum problem! (see other thread)
Old 28th September 2012, 02:47 PM
What you need is one of these, dispenses with the analogue tuner altogether.
http://www.ebay.co.uk/itm/1809802989...84.m1423.l2649
Old 28th September 2012, 03:18 PM
Only if you've got an RNS-D, it's not for RNS-C sadly
Old 3rd October 2012, 09:30 AM
Well now I am TOTALLY confused.
I've just taken delivery (thanks A8parts )of a 4D0 035 530 aerial unit with the "old type" connectors, with the original aim of dismantling it just to use the connectors.
But looking at it I really have NO IDEA where it goes and what it does!
It has no external power supply and only has 6 active sockets (of 8 - 2 have nothing behind them). It happens to have a few "cut off" leads/plugs with it, I presume originals as they've been cut (though one has been snapped out).
One group of 4 sockets have "thin" leads, so I "presume" these are TV aerials - but are they input or output? Logic says they should be the leads from 4 diversity aerials, but my TV tuner has 4 leads to it. And it really wouldn't make sense to have 1 aerial lead into a box like this leading to 4 to the tuner - or would it?
The other conector block only uses 1 and 4. #4 has a thin TV-type lead and #1 a stub of thicker coax that could be a radio lead?
So my interpretation of this box is that it takes input from 4 aerials and feeds a radio signal down one cable and TV down another. Power must come from outside somewhere, up one of the cables. I'll open it up soon to see if that gives any clues.
This does make me wonder how my car is wired up?
Thoughts anyone?
Old 3rd October 2012, 09:34 AM
- There is no ignition switched power feed to the tuner. Its a constant +12v and the tuner listens to Canbus for signals to turn on and off.
- Directly feeding TV into the Nav unit is a pain as it doesnt take a regular composite feed, its RGB which is what those splitter boxes do - However unless the splitter box generates a canbus signal to say 'im here' then the TV function will remain disabled on the Nav unit. They work well on VW MFD etc as they dont check for this signal. Leaving the tuner in place is always way easier....
Old 3rd October 2012, 09:50 AM
This is PF with RNS-C and Type A TV tuner, are you sure?
I had my multimeter out and there's definitely a black/blue lead that ONLY goes live (+12V) when the ignition is on.
I'm leaving the TV tuner in place anyway.
The aerial mystery in the previous post is much more intriguing though...
Old 3rd October 2012, 09:53 AM
Well, i was, until I actually read your sig after my last post and clocked the PF S8 part...
Still, its the same tuner and RNS-C gubbins that came with the early facelifts....
I need to have a look at some wiring diagrams me thinks to be 100% sure...
Old 3rd October 2012, 10:44 AM
Well this is what's inside. The reverse of the PCB is almost unused, just a handful of short tracks typically routing a group of (presumably) TV-related signals across something else.
The bottom left connector is the 4 TV aerials. Bottom right has TV on the left and radio on the right (my guess).
I'm also guessing that the chips are monitoring the TV signals and controlling some switches, you can see the 4 tracks converging into 1 in stages.
Couple of coils too, presumably for frequency filtering?
This "supports" my theory that this particular unit is an active diversity monitor switcher taking tv/radio input from 4 aerials and producing a single TV and single radio output.
But that makes no sense married with my 4-input TV tuner.
Not clear where the power for the chips comes from, or what voltage it would be.
Old 3rd October 2012, 12:29 PM
Red/Yellow is the constant + 12 on pin 2 of the 6 pin connector. The Red/Blue wire you have on pin 4 does indeedy appear to be a switched live....
Ground via brown wires pin 1 and 5, then Canbus pair on pins 3 and 6 with the grey/red and grey/white twisted pair.
On that model year, the AM and FM aerials are seperate items in the rear window which connect straight through to the Head unit in the front by the looks of it.
The black box you have there seems to be an aerial amplifier, more than a diversity switcher. Perhaps the Tuner does the switching internally and the aerials on your rear screen aren't self amplified like the later ones...?
I would assume the aerial connections out of the TV tuner are thus powered....
Why two of them seem completely unconnected however is a puzzle...
