Old 7th January 2013, 09:29 AM
Dave McB Dave McB is offline
Default 12v power sockets not working
Just discovered that both 12v power sockets on my 51 D2 aint working
I know they are on seperate circuits & iv checked the fuses. Seems odd that both aren't working
Is this a common occurrance or an electrical gremlin that needs looking at?
Old 7th January 2013, 09:48 AM
Have you got the window child lock button on? For some reason that sticks in my mind as something for the rear socket.
Otherwise, if the fuses are both OK, then something else sounds wrong.
Old 7th January 2013, 12:31 PM
yes the child lock is on for the windows
il re-check the back one & work from there ta
Old 7th January 2013, 03:57 PM
The rear is switched off when window lock button is pressed. Front one should be on all the time.
Are you trying the cig lighter or something else? Only reason i ask is the front one in mine did not work but will power sat nav ect, i thought the cig lighter had been lost and replaced by one not from the car maybe.
