D3 - Transmission Gearboxes, diffs, drive shafts. |
Hi, I've noticed a quiet droning noise as the speed decays through 60 mph on a trailing throttle. Been happening for several months without really changing. It happens in 5th or 6th gear and is immediately abolished by shifting into neutral. Gears shift well and car also drives well with no noises when cruising at 85 - just returned from the Alps. It is not tyres as still happening when I fitted the spares with snow tyres. I recently had the gearbox oil level checked and topped up and there's nothing on VAGCOM. Car is a 3 litre diesel sport with 94k miles and FSH. I recently replaced the front C links which improved the handling but made no difference. Any suggestions?
Cheers, Jem.
D3 2006 3.0 tdi sport, aqua blue, hybrid tv / DAB. Transmission fluid change for ZF lifeguard 8 at 100 000 miles. |
I've seen transmission drone on a D3 before, quite noticable wheel speed not engine speed and it went after a gearbox oil change.
I did also have a wheel bearing which manifested itself as a rumble only in certain situations. That was at around that mileage. That got progressively worse though over a few hundred miles, which you'd easily notice if you're doing some miles in it, so maybe thats less likely.
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Try changing all the transmission fluids with OE fluid.
Autobox is easy for a garage, maybe a little difficult for DIY because you need the car in the air and level Rear diff (easy as there is a drain plug and fill plug) Front diff (you need a vacuum pump such as a Pela) and then it's quite easy. The torsen transfer case looks difficult to get oil in and out due to being up in the tunnel and the adjacent exhaust pipes and I have never found a how-to. |
interesting ... i see many videos of people shifting into neutral while doing about 50 mph and then putting it back into drive ... is this safe to do on an auto box ? ive never done it.
Done it accidentally before... but I'd guess that the software would have a routine for that.
I tried shifting into neutral to get a feel for where the noise might be coming from, not something I usually do but hasn't upset the car as far as I can tell. The gears still shift almost imperceptibly and above 60 mph the car is absolutely normal. The noise does not occur in neutral but is the same whether in 5th or 6th gear. It's not very loud and wouldn't easily be noticed with the radio on. I'm not a mechanic but this suggests it involves the output end of the gearbox before the torque converter? Is there an intermediate bearing? I'm probably over analysing and its a case of ATF change and see. I was interested if anyone noticed a similar issue. Thanks for suggestions.
Jem
If you shift accidentally into neutral most car manuals tell you to allow the engine to drop to idle and then put the car back into D - should be no different to the car coasting already in D so won't do any damage.
Thats ok then so if im doing 50mph and put it in N i can still coast but let the revs drop befor putting it back in gear ?
Well I took the jump and and had the ATF fluid changed last week with ZF Lifeguard 8 as it was quite a lot less expensive than Audi OEM and highly rated by those in the know apparently. The old fluid didn't look too bad and there wasn't much stuck to the sump magnets at the time of draining (mileage exactly 100K). Since then I took a highly entertaining run to Ayrshire at the weekend to give it a good shakedown including fairly rapid run back down the A71. The verdict? The gearchange which was very smooth before is now all but imperceptible and seems faster in tiptronic mode. The car seems to drive even more effortlessly and there is also a marginal improvement in the recorded average mpg from 36.7 to 37.5. I wasn't expecting this but the car returned an indicated 41.6mpg for the Scotland journey and I wasn't hanging around which even impressed my diesel hatchback owning passenger. The droning noise however is still there and doesn't really seem to have changed. This was disappointing but the improved driving characteristics and confidence from having renewed the oil certainly justify the expense for me.
