Old 2nd February 2013, 03:12 PM
MAM MAM is offline
Disk 1 worked perfectly on the first try
Disk 2 is refusing to update the Bluetooth unit for me . Must I get this to work before installing Disk 3?
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 2nd February 2013, 04:24 PM
Nope.. you can do disk 3 after disk 1. Disk 2 only does the bluetooth module as far as I know.. and maybe just the Handyvorb one, so ifyou have the rSAP module, that may not be affected by the 'update of death' problem.
Old 2nd February 2013, 04:57 PM
MAM MAM is offline
Thanks, disk 3 is now installing.
Bluetooth may have a problem. I changed the module from a standard armrest one to the Bluetooth one - non rsap. The mmi now recognised the unit as nnnnnnnnnnnnnn in the module list. Is this component protection, or maybe a fried module?
Old 3rd February 2013, 11:13 AM
Try disk 2 again after disk 3, but it may have died
Old 3rd February 2013, 01:35 PM
MAM MAM is offline
I have tried a few times since installing disk 3 too, but there is no change.
With me changing the unit from armrest phone unit to Bluetooth, could vagcom be needed to change the module type?
Old 4th February 2013, 10:51 AM
its possible, is this a brand new unit or one that was fitted in another 8 before?,
do you have any old scans that show the telephone coding?
Old 4th February 2013, 03:39 PM
MAM MAM is offline
It was from another 8.
Neil has a scan from our last meet. It has not been re-coded since the install as none of the instructions have stated that it is required. I thought it was only because I needed the software update.
Old 4th February 2013, 05:34 PM
if you are getting over this way , i could take a look
Old 9th February 2013, 11:00 PM
MAM
i found some more info after the vagcom scan
there is reference to strange chararacters showing up as below
Address 77: Telephone Labels: None
Part No HW: nоооооооооо
Revision: оооооооо Serial number: оооооооооооооо
VCID: 55A40612FCA95FB022B
Subsystem 14 - Part No: 4E0 910 336 K
Component: ооооооооооооооооооо 0950
Shop #: WSC 61166 887 1957341
1 Fault Found:
02619 - Communications Wire Adapter Set
004 - No Signal/Communication
Freeze Frame:
Fault Status: 11110100
Fault Priority: 15
Fault Frequency: 254
They tend to say that it means the module is fried but there is one reference to it being possibly caused by the update cds, it might be worth getting a proper audi disk 2 and trying again before you rip it out
Old 4th March 2013, 07:42 AM
wug wug is offline
Originally Posted by limoncello View Post
there is something about parking in there
under DIAG SETTINGS
then APK 0Ч01, 0x0B, 0x0C
these 2 settings - you can also do it in vagcom
APS (front) - activation parking sensors front of the vehicle. Equivalent adaptation module 07, channel 1, the value 4
APS (rear) - activation parking sensors in the rear. Equivalent adaptation module 07, channel 1, the value of the 8th
Alright, i have looked into the hidden menu but couldn't find any relevant update to display APS on screen.
Also on VAG, where indicated there is something to change navi language. Am i doing something wrong?
