#51
Disk 1 worked perfectly on the first try
![]() Disk 2 is refusing to update the Bluetooth unit for me ![]()
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather Green Exclusive Dual Colour, Heated Comfort Leather Interior Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds |
#52
Nope.. you can do disk 3 after disk 1. Disk 2 only does the bluetooth module as far as I know.. and maybe just the Handyvorb one, so ifyou have the rSAP module, that may not be affected by the 'update of death' problem.
#53
Thanks, disk 3 is now installing.
Bluetooth may have a problem. I changed the module from a standard armrest one to the Bluetooth one - non rsap. The mmi now recognised the unit as nnnnnnnnnnnnnn in the module list. Is this component protection, or maybe a fried module? ![]()
#54
Try disk 2 again after disk 3, but it may have died
#55
I have tried a few times since installing disk 3 too, but there is no change.
With me changing the unit from armrest phone unit to Bluetooth, could vagcom be needed to change the module type?
#56
its possible, is this a brand new unit or one that was fitted in another 8 before?,
do you have any old scans that show the telephone coding?
#57
It was from another 8.
Neil has a scan from our last meet. It has not been re-coded since the install as none of the instructions have stated that it is required. I thought it was only because I needed the software update.
#58
if you are getting over this way , i could take a look
#59
MAM
i found some more info after the vagcom scan there is reference to strange chararacters showing up as below Address 77: Telephone Labels: None Part No HW: nоооооооооо Revision: оооооооо Serial number: оооооооооооооо VCID: 55A40612FCA95FB022B Subsystem 14 - Part No: 4E0 910 336 K Component: ооооооооооооооооооо 0950 Shop #: WSC 61166 887 1957341 1 Fault Found: 02619 - Communications Wire Adapter Set 004 - No Signal/Communication Freeze Frame: Fault Status: 11110100 Fault Priority: 15 Fault Frequency: 254 ------------------------------------------------------- They tend to say that it means the module is fried but there is one reference to it being possibly caused by the update cds, it might be worth getting a proper audi disk 2 and trying again before you rip it out
#60
Also on VAG, where indicated there is something to change navi language. Am i doing something wrong? |
