Old 4th February 2013, 10:17 AM
wug wug is offline
Default Acc/Start Auth. 5 Faults Found
Hi there,
i have some errors on my car and i would like to share with you maybe we can find a solution.
I will copy/paste the errors from VCDS log:
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0333088
Coding: 0409600
Shop #: WSC 02311 785 00200
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 265 081 F
Component: Heizgeraet H06 0290
Revision: 0000000F Serial number: 00000009001484
Shop #: WSC 00000 000 00000
VCID: D9B313BD1002D31
1 Fault Found:
01406 - No Flame
000 - - - Intermittent
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H06 0070
Revision: 06 Serial number: 0100403517015F
Coding: FEFFFFFF2B7504
Shop #: WSC 02555 823 55447
VCID: E5CB2F4D2C7A671
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Mileage: 166090 km
Time Indication: 0
Date: 2013.01.30
Time: 09:57:40
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0409600
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 B
Component: KLIMA-STG. FOND 015 0210
Revision: 00000014 Serial number: 00000000015239
Coding: 0000000
VCID: E1C33B5D38520B1
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
4 Faults Found:
02299 - Supply Voltage Seat Vent; Rear Driver Side
011 - Open Circuit
02300 - Supply Voltage Seat Vent; Rear Passenger Side
011 - Open Circuit
02291 - Control Module for Seat Vent; Rear; Driver Side (J674)
02292 - Control Module for Seat Vent; Rear Passenger Side (J675)
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000631
Shop #: WSC 52388 133 92782
VCID: 2045FE59F3D8C29
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 105
Time Indication: 0
Freeze Frame:
Voltage: 5.69 V
Count: 61
Address 66: Seat, Rear Labels: None
Part No SW: 4E0 910 860 HW: 4E0 959 860
Component: Sitz Fond H06 0050
Revision: 00000000 Serial number: 5DS 008 795-01
Coding: 0000009
2 Faults Found:
02318 - Potentiometer for Lumbar Height / Massage; Left Rear (G424)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 105
Mileage: 30696 km
Time Indication: 0
Date: 2005.03.11
Time: 11:54:00
02319 - Potentiometer for Lumbar Height / Massage; Right Rear (G425)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 105
Mileage: 30696 km
Time Indication: 0
Date: 2005.03.11
Time: 09:53:27
I can confirm the car battery is on 100% also both remote controls have new batteries.
