Old 9th February 2013, 01:26 PM
RanjS8 RanjS8 is offline
Default Windscreen replacement
I need to get the windscreen replaced on a d2 a8.....I know there are issues if it isn't done right....what are the issues and who is the best person to ask to do it?
Old 9th February 2013, 03:56 PM
It's not that bad tbh.. just make sure they use the right foam/right amount of foam at the bottom of it.
Old 10th February 2013, 07:37 AM
Problem is that they try to do it as quickly as they can to keep costs down. If you scratch through the paint you need to apply primer to prevent corrosion, wait for it to dry, then apply different primers to both car and new windscreen all around the perimeter to help adhesion, wait some more for them to dry and only then glue the windscreen in. Audi also use 2 component adhesive which come in 2 cartridges and mixes as you squeeze it out with pneumatic gun. It hardens quicker and stronger then one component adhesives.
Many fitters ignore any scratches and do not apply any metal primer, don't use any adhesion improving primer but instead use cheap one component primer-less adhesive. This way they can do it 1.5hrs instead of 3-4 and offer cheaper price or pocket more money. This can cause metal corrosion if metal primer was not used and in most severe cases windscreen can fall out couple of years later because all the metal under glue has corroded away.
Old 10th February 2013, 08:18 AM
Default Foam?
What is the foam?....is that the same as the glue that Ainar mentions?
Old 10th February 2013, 09:20 AM
Installing windscreen advice is HERE
Old 10th February 2013, 01:20 PM
Reffro Reffro is offline
Hi, the screen in the S8 was the second replacement screen I had done during my ownership. Both we were fitted one of the national companies. The work was done to a good standard each time, just make sure you get them to pack out the gap at the base of the screen with foam.
