Old 10th February 2013, 09:23 PM
RanjS8 RanjS8 is offline
Default Rns c retrofit
Well I m going to attempt this in the next couple of weeks and I am wondering if the following cable will work in getting it to work with the dis through the tmc module.
http://www.ebay.co.uk/itm/1207551036...ht_2283wt_1168
Thanks
Ranj
Old 10th February 2013, 09:29 PM
It would appear to have nothing to do with that at all...
RNS-C retrofit into what? An FL D2 that came with an RNS-D?
Old 10th February 2013, 09:32 PM
The rns c has no concept of tmc or any ability to talk to a tmc module..... So this cable is defo no good.....
Old 10th February 2013, 09:36 PM
Default Coool
So how does it talk to the dis???
Old 10th February 2013, 09:42 PM
Directly. The rns-c talks the same can bus as Audi, same as rns-e. it's only the rns-d that's a problem.
Watch the speed pulse input though. That has to come from from abs controller in the engine bay..... You can't steal a gala feed for the rns-c.
Very different DIS in FL vs PF for a start, or doesn't that matter....
Old 10th February 2013, 11:13 PM
Default Speed signal from abs controller?
Wow this should be fun!!!!! Not.
I can see a look at wiring diagrams coming up....
The Rns c is from a facelift a8....so DIS shouldn't be an issue.
I m looking forward to this install.
