Old 21st February 2013, 08:29 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
Looking back to when I did mine the part numbers are as follows:
ATF Oil G055162A2 - I bought 10 Litres but had about 2.5 left over
Strainer (filter) 09E325429
Sump Gasket 09E321371
Total Bill for that little lot was £375.00
Bear in mind the exhaust centre sections have to be removed to gain access to the sump pan and if these havent been off in a while the scope for damaging them is high as the flexy parts will most likely have corroded to the point of no return when you/the garage start moving them around. These cost around £400.00 per side.
On the plus side you will notice a difference - Compared to other D3's I had driven I thought my gearbox was smooth pre-service but afterwards the changes are almost imperceptable.
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 21st February 2013, 08:44 AM
sarg sarg is offline
I've heard this before, but I can say 100% that this was not necessary on my 2000 FL 4.2 QS.
Is this just for the S8?
Glyn, I don't have time to look for the threads right now, but there are 2 or 3 garages known to have the right gear and know what they are doing, personally I'd stick to one of those
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 21st February 2013, 10:00 AM
Glyn and David both have W12's Sarg
Wake up that man!!
Old 23rd April 2013, 11:25 AM
GlynH GlynH is offline
Well here's a (sort of) update;
Back in Feb this year I was quoted £333.00 to replace the gearbox oil on the W12.
The same place quoted me £284.78 to replace the gearbox oil in my D2 S8 but that included the oil itself, filter, gasket & sump bolts.
Rang this morning to get it booked on (as MOT has expired...don't ask) and asked them to replace gearbox oil at the same time.
Price has now gone up to £373.96 *OIL ONLY* and I am told I don't need a filter or gasket?
Apparently the W12 takes 10.8l at a cost of £28.33 p/ltr
The cost of oil is one thing but the thing that worries me is that I am told I don't need anything else despite asking that the filter be replaced and by definition the gasket if the sump needs to be dropped to get at it.
Seems strange that on the S8 they allowed for filter, gasket & bolts but tell me there is no filter that can be replaced on the W12?
According to Dave there is indeed a strainer/filter for the box and obviously the gasket to be replaced also...thanks for listing the part numbers Dave!
An exploded parts diagram showing the filter would be great if some kind soul out there has one please?
Is it possible to flush the box by removing oil cooler hose & pumping or dropping the oil, refilling, dropping again & then final refill or just drop & refill? Now that could work out expensive at £28.33 x 21.6l
If not flushed then I'm guessing all of the old oil won't be removed in which case I won't need all 10.8l recommended?
And is the oil fill procedure the same as the D2 ie. fill through the drain plug while monitoring temperature and running it through the gears or whatever the black magic art may be?
All these questions...
Car is booked in for MOT on Thursday so it would be ideal if someone could post a reply fairly quickly if possible please?
Thanks & kind regards,
-=Glyn=-
Old 23rd April 2013, 12:19 PM
on the copy I have access to it is coming up as -
MECHATRONIC WITH SOFTWARE
OIL SUMP
OIL STRAINER
----6HP26-----
3.7/4.2ltr. GNT,GNU,GQE,
4.0/6.0 ltr. GQF,GVK,GXL,
GUN,GZA,HCA,
HVV,HLM
with the following image -
Old 25th April 2013, 07:25 AM
Thanks for the reply AM,
Item 5 on the drawing looks suspiciously like a pan-type filter to me?
Well I emailed them on Tuesday but received no reply and car is in today so I told them not to do the oil change until we can get this resolved.
Wishing now I hadn't paid £373.96 up front for the oil...
-=Glyn=-
