Old 27th February 2013, 03:37 PM
Dave@A8parts Dave@A8parts is offline
Staff at A8 Parts
Default Prins LPG Kit for D2 40V Engines
We are now breaking an S8 2001 with a prins LPG system fitted.
The kit runs perfectly and switched to LPG fine.
All the wiring and hoses have been adapted for the D2 and it would be an easy job to fit for someone with the know how.
The kit comprises of:
- 8x Injectors
- Tank
- ECU
- Regulars
- Filter
- Filler system and cap
- Switch and gauge
This system is one of the best you can get.
It will pay for its self in no time in your greedy V8 D2
The car is in the process of being broken and the kit will be out soon.
Please call me on 01642 783537 if you would like any further information.
At Work to Drive:
2013 VW Caddy 1.6TDi Bluemotion, Highline, Heated seats, winterpack, DAB, Bluetooth, Lift up Tailgate, Colour coded, Leather wheel and gearknob, RNS 510 Touch Screen, optical PDC, HL Wash.
1997 S8, Pearl White
2005 W12 6.0, Heated Ventilated Massage Seats X4, Glass Sunroof, Fridge, RSE, Bluetooth, AMI, TV, Enhanced Leather, Heated Windscreen, 20" Alloys, ACC, Auto Boot, Soft Close Doors, 3 Electric Blinds, TP Monitor, Fingerprint
Old 1st March 2013, 05:24 AM
RanjS8 RanjS8 is offline
Default LPG kit
Hi do u have the original installation certificate?...would you happen to know how old the kit is please?
Thanks
Ranj
Old 1st March 2013, 10:50 AM
Staff at A8 Parts
Hi Ranj
We have all the documentation and certificates that will go with the system.
Please call me to discuss on 01642 783537.
Many thanks
Dave
At Work to Drive:
also would this fit my 40v d2 with minimal work ? im looking for cheap wafting other than the W12 all the time
and of course ... how much ?
Old 4th March 2013, 11:26 AM
Staff at A8 Parts
Hi Guy
This would fit your 40V A8 with minimal work.
Looking at offers around £600.
Cheers,
Dave
01642 783537
At Work to Drive:
Old 7th March 2013, 03:19 PM
ulfilias ulfilias is offline
If the engine is dead / being stripped are you not tempted to sell the head covers with the injectors.....Then it would be a bolt across item. I considered doing this with mine as it has LPG and the engine has some issues a year or two back (timing chain lifters)
Lee
Old 7th March 2013, 03:56 PM
Default LPG injectors
I maybe wrong but aren't the LPG injector pipe just sealed or screwed into the intake manifold?....so just needing the swap of the intake manifold?
Old 8th March 2013, 07:55 AM
RanjS8,
Hi there, for sequential multipoint, which is what this kit would be, then the injectors get places as close to the origionals as posible.
EG
http://www.gasautogas.co.uk/projects/14.jpg
Lee
Old 8th March 2013, 10:51 AM
Default Manifold
Cool in that case it is just the intake manifold that will be needed which would most likely just be a straight swap for the existing manifold....don't have to worry about the heads.
Btw I don't actually that setup cos if you have an issue with the coil packs or want to change the spark plugs then the LPG injectors points are in the way.
I had a setup where the LPG injector setup came from the centre of the manifold....it meant that servicing the car and any misfire issue were easily resolved without disturbing the LPG system.
Ranj
