Old 12th March 2013, 07:36 AM
Aren't the OEM arms both 22"?
IIRC my aftermarket "aero" blades are 24" (driver) and 23".
Old 12th March 2013, 08:54 AM
Well, I took your advice and bought the blades from TPS. £28.56 including VAT - and they do seem much better (but yet to put them to the test).
BUT - I expected the passenger side to be shorter. Can anyone check the part numbers for me?
S 4BO 955 425 (with aerofoil or whatever it;s called)
4AO 955 425B
Thanks
I can't check the numbers for you Jim, but at that price you had to buy the whole assembaly (with aerofoil), now you have the OEM blades next time you need to change them you can replace just the rubbers at around £8
In this photo you can see one of the metal strips that hold the rubber in place, (there is one each side), you remove these and side rubber out as in second photo.
Name:	wiper rubber.jpg
ID:	5726   Click image for larger version
Old 12th March 2013, 03:20 PM
The OEM ones definitely feature a shorter blade on the passenger side Jim, and also the curve is different on each blade too
Old 12th March 2013, 04:47 PM
Any idea how I can get hold of the correct part numbers to launch a dispute?
Old 12th March 2013, 05:05 PM
If ordered separately: 4B0 955 425 + 4A0 955 425 B
2 wiper blades in one kit: 4B0 998 003
One rubber: 895 955 429 A
Interestingly, the same wiper blades are used on A6 C5 and A8 D2.
Old 12th March 2013, 05:10 PM
Mine say that's what they are:
S 4BO 955 425 (with aerofoil or whatever it's called)
4AO 955 425B
But I'm pretty sure they're the same length....off to check before it gets dark
Old 12th March 2013, 05:12 PM
They are the same length (550mm). Hence the same rubber part for right and left.
Old 12th March 2013, 06:14 PM
Just measured my blades (probably non-OEM - they have no writing on them apart from "2Edge") and they are both 22inches (559mm). Both look the same and both are very curved.
Old 12th March 2013, 08:59 PM
mine are both 22in, (£4.99 Aldi specials), been on for two years worked great and just beginning to think they might need replaced soon
Old 13th March 2013, 01:52 AM
heres the post when Oli did his -
http://forum.a8parts.co.uk/showthrea...ghlight=wipers
I haven't gone and measured mine Jim so might be my mistake - sounds like they are the same length after what others have written/checked, but one is definitely "more curved" but you'd better not launch an "eBay prosecution" just yet!
