Old 2nd April 2013, 08:38 AM
My only dislike about the lighting at the moment is the non oem blue bulbs up front, but not bothered enough to spend 10 mins changing them
Do you mean the main beams?
I had one fail; and bought some (many years ago now) that were whiter/brighter to try to better match the Xenon's and was reasonably happy with that.
Since then bulb technology has improved so you'd probably have a wider choice and get something brighter too as they're a bit feeble.
Not sure on 10 minutes though, you need to take the ballasts off the back and probably remove the air filter box in its entirety too to get at the things.
The guy I bought it from set the lights up very non-standard, which I reverted. He had realigned the Xenons upwards (a lot) to act as a main beam and used the foglights (which not everyone will know are in the main cluster) as his dipped beams.
Old 2nd April 2013, 09:16 AM
The 'tan' leather always looks worse in pics, but it's nice in the flesh.
You need to get the start button upgrade installed... The big round silver one does look a whole load nicer than the plain black square one.
Old 2nd April 2013, 09:31 AM
Its fingerprint... no can do...
Old 2nd April 2013, 10:33 AM
Just realised, you probably meant the indicators, which I'd forgotten were a bit naff.
I confess to having bought some allegedly "chromed" indicator bulbs rather cheaply that were actually not a great look having a blue-ish surface so I didn't use them straight away.
But when a bulb failed I fitted them both anyway. Getting some better-looking ones was then put on the "round tuit" list...
Mind you, 10 minutes to swap those is generous, provided you can get your fingers in to release the rather oddly-shaped indicator unit retaining catch.
Old 2nd April 2013, 10:44 AM
A bit?...
Yes, they are the ones that bug me....
Old 2nd April 2013, 10:51 AM
Heres a couple of D2 wood steering wheels - the first was the one that Carrot Cruncher down in Bristol fitted to his car and the second is one that Oli found on a polish registered car -
Name:	wood steering wheel d2.jpg
ID:	5804   Click image for larger version
Old 2nd April 2013, 11:05 AM
Sir WIll Sir WIll is offline
Raaaaawr
Yep would LOVE a wood steering wheel in the old D2. I shall have to keep an eye out on eBay!
Old 2nd April 2013, 11:16 AM
Ah yes, I forgot about that most noteworthy car, which I have seen in the flesh (commence backpeddling on comment about never seen one)
Noteworthy as it has horrifically expensive Factory PF D2 Sat Nav option, and wooded wheel and no other options that I recall - Not even heated seats... Still. Cheaper to retrofit heated seats than the Sat Nav
Old 2nd April 2013, 11:24 AM
Where would a wooden wheel come from, it's certainly not an option in my late 1998 PF price list?
Old 2nd April 2013, 11:27 AM
Wasnt available on PF - Check FL pricelist...
