Old 3rd April 2013, 06:34 PM
Mic has always sat Passenger side. .............
Behind A pillar is easiest.............
Looking again the mic can't actually be swapped with the electrical connectors, so nearside it is.
I'm thinking of using the same route I used on my focus for some auto-dim mirror wiring, basically around the edge of the windscreen then between the main dashboard moulding and the A-pillar trim and down near the door.
A thin cable can be tucked away there invisibly and quickly and if it's on the nearside can go straight into the glovebox to the bluetooth unit.
Yes, Ian, I know you wouldn't do that.
Old 5th April 2013, 05:42 PM
The other panel with the lights in seems rather firmer and I didn't get it out, though I didn't try too hard just in case.
Just for reference I did finally get it out today. It was in VERY tight.
The fixing is a sort of mirror image of the switch panel, so metal spring clips at the REAR which once levered out unlatches the plastic lugs at the front of the panel.
The edge that needs to be levered is recessed into the surround and extremely tight so you need a thin, strong and wide tool and a lot of force. Take the bulb cover and bulbs out first.
It is so tight on mine that once I'd put it back I couldn't get it out again. (well I didn't want to try hard enough)
On mine the switch panel in contrast is very easy, in fact it will come out by just grasping the sunroof switch and pulling down and backwards releasing the front edge. And that's the only one I need to take out to fit the microphone.
And I've checked that route in detail and there are no obstacles to getting the microphone cable (with plug already on) hidden all the way from behind the light panel into the glovebox.
Old 8th April 2013, 12:16 PM
All fitted, neat and tidy and working. The microphone supplied with the kit works reasonably OK tucked away behind the panel in the roof even though it's largely baffled as I've not oriented it very well.
I've ordered an OEM microphone from A8parts and will see whether that improves audio quality, though I think the main quality problem is really using a bluetooth-linked phone handset transmitting from inside the car without an external aerial.
