Old 17th April 2013, 02:49 PM
madcjd madcjd is offline
Default Electric boot release
Hi all.
Problem (recently) - upon activating switch on door to release boot, it unlocks the boot, makes an effort to open boot, only opens a tad then immediately closes.
Any suggestions.
Need to sort this out as I'm sticking the car up for sale soon.
Thanks, Chris
Old 17th April 2013, 04:08 PM
If you help it up a little, does it still go?
Sounds like the lift motor is on the way out.
Old 17th April 2013, 08:18 PM
Getting old, can't get it up anymore
Old 17th April 2013, 08:56 PM
Pop a viagra in the boot and see what happens lol
Old 21st April 2013, 10:09 PM
47p2's Avatar
47p2 47p2 is offline
As already said it's most likely the motor's getting weak, it was a poor design, you could try oiling the hinges as they require regular lubrication
Nite Blue 3.0L SE Quattro
Old 22nd April 2013, 03:31 PM
If the motor is still working (?) but struggles to get it up then it may well be a lubrication problem as 47P2 suggests. Usually motors (in my limited experience work or dont work - unless its a brushes problem which usually results in erratic behaviour). What is the drive mechanism? geared? Cable?
(having read that again I can see that this subject is open to much hilarity)
